Build Olds 403ci/6.6L Engine
Old Jun 7, 2022 | 08:31 AM
Zennex's Avatar
Built 403ci small block. Casting number says it's a 1978 model from a Pontiac Trans Am. Originally had 50,000 miles when I started working on it.
Has new Comp Cams aluminum roller rockers, Comp Cams .520/.523 camshaft and High Energy lifters, Flowkooler high volume water pump, Melling high volume oil pump, Milodon 7qt oil pan, Mondello 5 cap main girdle, Milodon main and head studs. Heads are ported, light bowl porting and standard valves.
$5,000 and it comes with a new Edelbrock Victor single plane intake, $4,500 without intake. Was originally going to be a turbocharged project.
Not 100% if I'm selling this, just looking at offers for the moment. Make an offer, may be willing to go down in price or trade.
Message me here or email at chrisscottturner@gmail.com. Text 440-650-4068 because I'm bad at answering calls.
Old Jun 9, 2022 | 04:42 AM
p518's Avatar
I may have missed it. What pistons and rods? Estimated compression ratio? Who did the machine work and assembly?
Old Jun 9, 2022 | 12:43 PM
Zennex's Avatar
Stock 4.351" hypereutectic pistons and replacement I-beam rods. Block was only rehoned since 403s are kind of prone to cracking cylinder walls with overboring. Honing was done at a local no-name shop. Current static compression is 8:1 because I was planning on running a good amount of boost through it.
Old Jun 10, 2022 | 05:39 AM
p518's Avatar
Thank you for this information.
Old Jun 10, 2022 | 09:41 AM
Which model Comp Cam or failing that, what are the duration numbers @0.050 and LSA?
oldsw30
Feb 23, 2022 09:11 AM
yogieb123
Oct 6, 2014 11:21 AM
coppercutlass
Apr 2, 2014 07:45 PM
danthedirtguy
Apr 13, 2013 11:31 PM
