64 F-85 steering wheel and Harrison radiator, manual gear box
64 F-85 steering wheel, ( could be 65-66 check your part numbers). Has some cracks as shown but seems to be in better condition than most of the ones I have seen, the brushed horn set up is in great condition-$80.00. Also I have the column shifter available that was re-chromed $50.00 (paid 100.00 for re-chroming) Had the original Harrison radiator re-cored and had the lower outlet moved over to the passenger side-64's had the outlet on the drivers sided requiring a 64 only water pump.I filled this radiator once to start the 330 before I took the car apart. Asking $165.00, Manual gear box $100.00
Stan 65 , this is out of my 64 F-85 pro-touring build. Was a 330-Jetaway trans, manual steering gear box, check the part numbers. I don't know if there is a difference. I would not think so. I can send you the part number
Swede64, re-cored for 330-SBO. The car was sitting for over 25 years, I wanted to see if I could get the 330 running so I could sell it when I took the car apart. The 330 started up and ran perfect. And yes it's for an automatic trans
metalmen
November 29th, 2013 07:24 PM
March 8th, 2013 07:26 AM
WTony
December 23rd, 2011 08:22 PM
