64 F-85 steering wheel and Harrison radiator, manual gear box
Old Feb 2, 2015 | 03:32 PM
therobski's Avatar
64 F-85 steering wheel, ( could be 65-66 check your part numbers). Has some cracks as shown but seems to be in better condition than most of the ones I have seen, the brushed horn set up is in great condition-$80.00. Also I have the column shifter available that was re-chromed $50.00 (paid 100.00 for re-chroming) Had the original Harrison radiator re-cored and had the lower outlet moved over to the passenger side-64's had the outlet on the drivers sided requiring a 64 only water pump.I filled this radiator once to start the 330 before I took the car apart. Asking $165.00, Manual gear box $100.00
Old Feb 2, 2015 | 03:53 PM
stan 65 cutlass's Avatar
is that a FOURSPEED manual gearbox for $100 ??
Old Feb 2, 2015 | 04:32 PM
therobski's Avatar
Stan 65 , this is out of my 64 F-85 pro-touring build. Was a 330-Jetaway trans, manual steering gear box, check the part numbers. I don't know if there is a difference. I would not think so. I can send you the part number
Old Feb 2, 2015 | 04:34 PM
therobski's Avatar
Stan 65 now that re-read my post, sorry its a manual steering box, not a 4 speed manual trans box!
Old Feb 2, 2015 | 04:48 PM
i figured that out, just yankin yer chain rob
Old Feb 5, 2015 | 02:13 PM
Swede64's Avatar
I suppose it´s a automatic transmission radiator? Did you recore it to be used with a BBO or a SBO?
Old Feb 6, 2015 | 06:15 AM
therobski's Avatar
Swede64, re-cored for 330-SBO. The car was sitting for over 25 years, I wanted to see if I could get the 330 running so I could sell it when I took the car apart. The 330 started up and ran perfect. And yes it's for an automatic trans
Old Feb 6, 2015 | 02:51 PM
2blu442's Avatar
PM sent on the steering wheel.
John
Old Feb 8, 2015 | 06:41 AM
therobski's Avatar
Steering wheel is sold
yankees
Nov 3, 2014 05:00 PM
metalmen
Nov 29, 2013 06:24 PM
ManCutty
Oct 4, 2013 10:03 AM
Mar 8, 2013 06:26 AM
WTony
Dec 23, 2011 07:22 PM
