Touch up or too far gone??
Old Jul 25, 2021 | 02:34 PM
brotherGood's Avatar
Not sure who all has followed my build thread, but long story short my '69 442 was pulled out of the PO barn and was is pretty good shape considering where it's sat and for how long.
That being said, there were a couple of minor issues with the paint..the biggest issue being just behind the drivers door due to a pocket knife when being pushed in the barn.
We tried the touch up paint route with the object of a wetsand and polish, but after doing a much less conspicuous spot aren't feeling so great about it. Here's where we sit now (went ahead and buffed it a few times just to see if it'd do anything)
Should I go ahead and try it, or since this is the worst of it just go ahead and let a professional do the filling/blending.
Old Jul 25, 2021 | 02:45 PM
You might be able to give it a light sanding with some 3000 grit wet sanding to smooth it out and then polish with a buffer. To truly fix it right it would need a repaint and color match.
Old Jul 25, 2021 | 07:41 PM
truckman5000's Avatar
W30
Agree with above
looks like in the clear finish.
I'd take it to a body shop to make quick work of it
Old Jul 26, 2021 | 02:21 AM
I had the thought of sanding and using the touch up spray along the area, that way it would have a better chance at blending..I just don't know for sure how that'd work as far as the clearing went.
I've done flat panels such as a trunk, and done this on a cheap car that didn't have much shine to begin with..never something like this.
Old Jul 26, 2021 | 05:22 PM
Which Duplicolor paint am I looking for? I just picked up the "Light Addiction Red" and sprayed it on a piece of metal in the garage and it has too much red in it.
The other close one I remember was a "Dark Toreador" but using the picture test it looked almost a little too dark at the 'Zone.
Thoughts?
Old Jul 26, 2021 | 05:34 PM
Tedd Thompson's Avatar
I would not trust a spray can touch up. Chances are even if you get an exact match it will fade differently as time moves on. If there is a real automotive paint store in your area have them match it up in the smallest amount they will mix. Not cheap but the pigments are much more color fast and much easier to apply. Do you have a air brush sometimes that and masking tape and a buffer will do wonders....Tedd
Old Jul 27, 2021 | 02:55 AM
I dont have an airbrush, but that's not a bad idea. I bought a decent sized jar of touch up paint (to be brushed on) but I suppose I could use it as if I were painting a model.
We've got a couple body/paint shops here in town, but I am shooting to do this myself if possible for 2 reasons. 1. I'm still waiting on the engine shop, and 2. It'd be much more budget friendly provided I can do a good job.
Old Jul 27, 2021 | 04:50 AM
You cannot spray and blend a small area on a big flat panel, it will stick out like sore thumb.
Old Jul 27, 2021 | 10:46 AM
Even with distance and light mist?
Old Jul 27, 2021 | 12:02 PM
RandyS's Avatar
No way. They make a blending spray, but as Eric said, you don't want to try to blend on a big flat panel. The entire panel needs to be resprayed, you can cut it at body lines or natural gaps.
Old Jul 27, 2021 | 12:09 PM
Gotcha. Shop it is I reckon.
that opens the other can of worms though. Do I keep the non-original color or go back to Nassau Blue. That way the only thing non-original per the tag would be steering wheel (still have the original) interior color (was parchment bench, now black bucket/console) and wheels (I have later SSII's that came with the car)
Old Jul 27, 2021 | 01:01 PM
If you like the color keep it, however getting 1 panel done vs a complete paint job is a considerable cost difference. Pretty soon you'll be moving to a complete frame off.
Old Jul 27, 2021 | 01:08 PM
We call that "mission creep"!
Old Jul 27, 2021 | 01:35 PM
yeah, I know...its a great idea until price is involved 🤣
Old Jul 27, 2021 | 07:21 PM
Well, learned something new today...
i was always under the understanding that the paint correction process was mainly for swirl marks, but my father in law stopped over and did a bit of it this evening on the issue area and it blew me away..
once the car is drivable and whatnot, I'll run it out to his garage and we'll finish the correction, do the entire car and go ahead and coat it.
OLE442
Paint
Apr 24, 2020 08:16 AM
rennoc442
Nov 10, 2017 05:36 PM
smash72
May 23, 2016 03:21 AM
Doug69Cutlass
Jan 28, 2010 03:01 PM
derek nesdoly
Care and Appearance
May 29, 2009 04:23 AM
