Touch up paint won't buff out the same as original
I'm doing a little touch up on a finder skirt that has scratches from of all things a roll of carpet falling off a rack in my garage and putting a three inch series of scratches on the skirt,only hit the skirt. I have sanded and filled with non hardened acrylic enamel all the damaged area. The problem is when I buff out the surface using Speed Glaze the patch / repair has a different gloss. Is this because it not a hardened product? Is there a better way to do this or should I just respray the skirt and be done with it this spring...Tedd
Touch up will never truly match. Specially when the color is more "concentrated" when you spray the color it's atomized when you touch it's more concentrated . Try to thin it out a bit. As it might be saturated with pigments also make sure your paint is fully shaken up.
There IS a solution to the mismatch that can be easily corrected when you think about it. Time to get the whole car repainted.... and someone told me once that rug burn goes away with no nasty marks afterwards.
Seriously, I'd just respray the skirt and be done with it. Less time fixin, more time drivin...
PS I am still all busted up with this knee replacement so things are going very slow so don't expect film at 11 but it will happen.
