Rust encapsulator vs. rust converter
Old February 23rd, 2017, 08:55 AM
I have to admit that I've been confused about which to use when. This how-to from Eastwood just dropped today. It clears it up, but unfortunately I apparently did the wrong thing on the suspension arms for my 67.
https://garage.eastwood.com/eastwood...ontent=1EM4661
joe_padavano is offline
Old February 23rd, 2017, 09:26 AM
Cincinnati Rick's Avatar
Good info Joe. Thanks for posting
Cincinnati Rick is offline
Old February 23rd, 2017, 09:55 AM
Thanks for the link.
Olds64 is online now
Old February 23rd, 2017, 12:27 PM
bccan's Avatar
IMO Rust converter is garbage, use POR-15 or similar if you're not going to remove the rust.
bccan is offline
Old February 23rd, 2017, 12:37 PM
Well, Eastwood's Rust Encapsulator is their version of POR-15. Same stuff, same cures with humidity. Per that article, the converter (and again, everybody sells a version of this) is only for very scaly, pitted rust. I can't ever see using it on a car - at least not one I cared about. On the other hand, it has a purpose on things like rusty trailers and such. You're supposed to top coat the converter with POR or Rust Encapsulator, or similar paint.
Old February 23rd, 2017, 03:05 PM
Tedd Thompson's Avatar
back in the day I sold probably a thousand gallons of Rust Destroyer. This product has a rust converter + a encapsulate in it ,will take hot solvent top coats or epoxy's after 72 hours cure, sticks to many surfaces other than ferrous(stainless copper aluminum). Does not need a top coat(holds up to UV by itself) and goes on much like a fill coat would and will mask many rust dempled areas with two coats, about as close as a all in one coating as can be found. Good stuff, never had a come back/ complaint that I can remember in over twenty years. Burnt red in color.. I'm not involved in this product anymore, no skin in this game.... Tedd http://www.thepaintstore.com/Advance...er_p/73001.htm
Tedd Thompson is offline
Old February 23rd, 2017, 03:10 PM
Thanks. I had not heard of that product before. I'll have to try it. I use Rust Cover Paint from TP Tools. Another POR clone, but TP claims theirs is UV stable. I haven't had it out in the sun long enough to verify that yet.
Old February 23rd, 2017, 04:46 PM
therobski's Avatar
Joe, I used the Eastwood rust encapsulator sparingly as need on the F-85 build, example in the picture. I wired wheeled etc. off the surface rust best I could. I actually let one coat cure and hit again. Good stuff for these purposes.
therobski is online now
Old February 23rd, 2017, 05:07 PM
Out of Line, Everytime😉
olds 307 and 403's Avatar
I have used rust converter a few times, actually so far so good with the 70, I left it on overnight, might have helped. POR 15, seems cool, even after pretreating with Marine clean and neutralizing, the rust came back. I have used Rust Destroyer a little, like primer but much more money.
olds 307 and 403 is offline
Old February 24th, 2017, 05:43 AM
I've used this stuff before along with a wire wheel to treat rust before coating it with Rust-o-leum:
Amazon Amazon
Old March 30th, 2017, 06:16 PM
1970greensupreme's Avatar
I just bought some ospho rust treatment. It will be used in places where you can't get paint, floor braces, fuel tank supports. It's a thin liquid and can be sprayed on with a sprayer and for places you simply can't access it should do the trick.
1970greensupreme is offline
Old October 27th, 2017, 02:44 AM
nohitver's Avatar
I have a good experience with rust converter! Actually rust gets disappeared after applying rust converter. The thickness of surface remains same after using rust converter.
nohitver is offline
GINCSC
December 19th, 2015 01:49 PM
lvnfld
November 27th, 2015 07:28 AM
A72CUTLAS
Paint
25
March 31st, 2011 03:46 AM
easytobedead
Paint
April 10th, 2009 06:16 PM
rickie
January 11th, 2003 11:34 PM
Quick Reply: Rust encapsulator vs. rust converter
