Painting bare steel wheels
Old Nov 20, 2025 | 03:37 PM
AzMotorhead's Avatar
QUestions for the paint pros here. I have a set of SSII''s and Thortons Argent wheel paint. Steel is bare and clean.
Can anyone advise me on what primer I should use, do I need to seal it afterwards prior to applying the argent topcoat.
Backside of the wheels I'll be painting semigloss black.
I repainted my original SSII's decades ago with paint from Greg Rollins (rest his soul). Cant remember what steps I did they have held up well.
New wheels have chrome hoops and have been widened and made into 15's
Old Nov 20, 2025 | 04:15 PM
redoldsman's Avatar
Proud Viet Nam Veteran
About three years ago I had the wheels on my 75 Hurst sandblasted and then I painted them before I had the new tires mounted. I sprayed them with a rattle can of epoxy primer. I think I bought it from Amazon. It is the two part that you have to activate and use right after you activate it. I bought two cans but one was enough to cover the wheels nicely. Then I sprayed them with single stage acrylic enamel with the hardener in it. They turned out very nice and have held up well.
Old Nov 20, 2025 | 05:37 PM
The last set of wheels I painted were 15” SSIII that I stripped to bare metal. I bought cans of spray primer at a local automotive paint store and didn’t realize until after the wheels were painted that some were etching primer and others were regular primer. 10+ years later the wheels look the same, so apparently it didn’t matter which primer was used. The top coat was acrylic enamel, with nothing on top of it.
Old Nov 21, 2025 | 04:18 PM
ijasond's Avatar
Purveyor of Polyurethane
I second this recommendation.^^
Old Nov 22, 2025 | 08:18 PM
I had blasted a set of steel wheels for my driver. I scuffed them and painted them four coats duplicolor spray primer all over (front, back, inside tire). Then, I painted the front and back Duplicolor Universal Silver four coats and did not care about overspray into the pressurized area as it was primed there.
I am about to take those rims off the truck, 60k+ miles later, parking outside, after 8 years or so. The wheels are starting to get rust through the paint now. Doing this to an indoor parked car getting 10% the miles should last 20 years.
Greg Rogers
Wheels and Tires
Dec 5, 2022 04:53 AM
Delmont1968
Paint
Aug 24, 2022 02:52 PM
razman427
Jul 14, 2018 09:46 AM
Harp 1
Wheels and Tires
Mar 31, 2018 07:30 PM
442dreamer
Wheels and Tires
Jun 11, 2011 09:04 AM
