How much paint
Old Nov 28, 2025 | 11:10 AM
BBLima's Avatar
How much paint
I am getting closer to the final paint stage. Im going to hit it with sealer than with a base coat clear coat.
I am doing the entire car, door jams, full trunk etc. Its a hard top. My question is how many gallons of base will be needed thinking 3 max coats. My base is 1 to1 ratio
so it will give me 2 gallons. The paint code is 11 cameo white. Im using ppg for paint the car is a 1972 hurst olds hard top
Old Nov 28, 2025 | 11:13 AM
It would be good to know what kind of car. A 98 will take more paint than an Omega.
Old Nov 28, 2025 | 11:14 AM
BBLima's Avatar
lmao yeah I think that would be important
its a 72 hurst/olds hard top
Old Nov 28, 2025 | 03:24 PM
Andy's Avatar
Definitely need to know what car.. are you using PPG shopline or PPG deltron? Deltron costs 3 times plus what shop line costs but definitely covers in less coats. Shopline, depending on the color can take anywhere from 3-6 coats to cover. I am doing a 66 442, shopline. I bought 1 gallon and 2 quarts of base because I will be doing some practice on a fender to get my technique correct. It’s a metallic so I am nervous about it no doubt. Better to much paint than not enough
Old Nov 28, 2025 | 03:28 PM
BBLima's Avatar
ya I agree with that thinking buying 2 gallons just to have back up for future.
I added the car. Lol im using ppg deltron for base coat
Old Nov 28, 2025 | 03:34 PM
Andy's Avatar
you definitely have enough. What clear are you using?
Old Nov 28, 2025 | 03:41 PM
BBLima's Avatar
if I can get away with buying 1 gallon of base and have left overs for future touch up would be ideal for my pocket. For the clear coat going with ppg dc5050
Old Nov 28, 2025 | 03:43 PM
BBLima's Avatar
Are you doing jams, trunk? Are you going with ppg?
Old Nov 28, 2025 | 04:53 PM
Andy's Avatar
Yes, ppg shopline metallic base, doing jams and and all yes.. ppg dcu2021 clear
Old Nov 29, 2025 | 05:23 AM
chopolds's Avatar
1 gallon of base should be all you need, even with shooting the jambs and trunk underside. Just chose a sealer that's close to the color, in your case, white or light grey. Now clear, probably need a gallon and a quart. Not including reducers and hardener.
Old Nov 29, 2025 | 06:06 AM
BBLima's Avatar
Thanks for the input!! Think ill have leftover base with just 1 gallon? Or should i buy an extra qt an mix them together and then keep whats left ?
Old Nov 29, 2025 | 07:35 AM
ijasond's Avatar
Purveyor of Polyurethane
I would typically use 3 rts quarts on the exterior of a car that size and then another 2 to do the jambs. 8 sprayable quarts should do the job with enough left over to hit the whole exterior again. But if you are unsure, just make sure to use a white sealer. I spray a lot of Nason on budget jobs and I can pretty much get away with one good coat of base over white sealer, but always use 2. Very rarely 3 on more transparent pearl colors.
In your original post you said it’s cameo white, but in another comment you mentioned it’s a metallic color. I’m confused. Either way it should be enough, but white base over white sealer can be done with far less paint than a metallic color.
Old Dec 2, 2025 | 07:18 AM
BBLima's Avatar
I am using cameo white on my car, Andy is using a metallic for his car that he mentionedin my post. I appreciate The info. im going with 1.25 gal on base 1.5 on clear. They do have a white sealer but I find it difficult to see what has been sprayed especially on the roof I'm going to see if I can get a light gray and hope 2 coats will be good. I bought a inflatable spray booth and Im got some led light stripping to hang down the sides. Man I hope this goes good as planned lmao. A practice panel will be in play to set pressure right.
Old Dec 2, 2025 | 07:32 AM
1966442's Avatar
When you think it is covered put on 1 more coat of base. Also make sure you pre mix all the base together
Old Dec 2, 2025 | 08:18 AM
BBLima's Avatar
thank you!
firstoldsmobile
Jan 17, 2017 07:55 AM
scott strange
May 8, 2012 04:12 PM
scott strange
Paint
Oct 20, 2010 07:57 PM
Chumley
Paint
Mar 31, 2010 07:51 PM
Ranzan
Feb 14, 2010 04:46 AM
