Laquer paint
Old Feb 20, 2012 | 04:32 PM
scott strange's Avatar
Laquer paint
I am going to have my 1971 cutlass re-painted and it has Laquer paint on it.Will I need to strip all of this off the car in order to go back over it with base/clear?? If so, whats the best way to remove the old paint? Thanks.
Old Feb 20, 2012 | 05:03 PM
Rickman48's Avatar
I'd go with media blasting.
Old Mar 26, 2012 | 06:20 PM
Shradezz70S's Avatar
Repaint
If you are going to paint it with base clear you will not need to strip it all off. If you were going to paint it with laquer you would. laquer paint is only paint and laquer thinner so it will bubble or strip everything else it is sprayed over.
Old Mar 26, 2012 | 06:54 PM
gbodyfan's Avatar
I would strip either have it blasted or use stripper
Old Mar 27, 2012 | 10:59 AM
Run to Rund's Avatar
If you get the surface smooth with a DA sander, you can epoxy prime it (e.g. PPG DPLF) and then top coat with base/clear or lacquer. You don't have to remove all the old lacquer to re-coat with lacquer.
Old May 8, 2012 | 05:33 AM
Eddie Hansen's Avatar
I have never heard this? Lacquer paint jobs are by nature many coats, wet sanded between etc, when they did repairs in the 'old days,
' they didn't strip down to bare, metal. The rule used to be lacquer or enamel over a lacquer paint job or enamel over enamel... I have seen lacquer 'craze' paint but generally not if it was a quality paint and if you primered.
I always thought if the old paint was in good condition, no checking,crazing etc then scuff prime and paint. ( lacquer/enamel) now with BC/CC I agree with r 2 r that seems to make sense I have ony sprayed lacquer, but plan on BC/CC on my project.
Old May 8, 2012 | 02:42 PM
Olds_71_442's Avatar
I'd get rid of all the old lacquer paint. In my experience, no matter what you put on it, it's going to wrinkle. The only paints I've ever left on a car are epoxy paints.
Old May 8, 2012 | 04:12 PM
justinj's Avatar
I think you've got it reversed.
Scott - If you want to spray over with Lacquer, you'd be fine without taking all the paint off. It is recommended that you at least use a sealer (or high quality Epoxy Primer) on top of lacquer if you're going to use BC/CC.
If the lacquer is in bad shape (i.e. cracking, crazing) I would strip it as close to bare metal as you can.
You can still find lacquer paint out there if you look. If you are doing the job yourself that is probably the easiest route + you won't have to deal with the isocyanates in the paint.
Jamesbo
Paint
Jun 13, 2020 09:02 PM
JpMotorsports
May 15, 2014 07:08 AM
dlmsavings1
Sep 3, 2013 09:01 AM
MLK-442
Aug 29, 2011 06:46 PM
ed burke
Paint
Oct 25, 2010 06:47 PM
