Paint code 67 442 3 pieces top grilll above lights
Old Nov 16, 2021 | 01:02 PM
duramaxcruzer's Avatar
the 3 pieces above the grill and headlights are silver need paint code for it thanks Al
Old Nov 16, 2021 | 01:26 PM
Oldsmaniac's Avatar
Don't know code but Krylon Dull Aluminum is a perfect match.
Old Nov 24, 2021 | 06:19 AM
dcook442's Avatar
Go to your local jobber and match the silver to your original piece. Buy the base coat and matching activator. The gloss will depend on how much activator you put in it, so do a test panel. Anything in a spray can will not last if it's in the sun much.
Old Nov 24, 2021 | 06:25 AM
dcook442's Avatar
Also, use a good epoxy primer and stay in the recoat windows for maximum adhesion!
Old Nov 24, 2021 | 07:57 AM
67 442 paint
67 paint thanks for reply paint is so faded not possible to match need paint code thank you
Old Nov 24, 2021 | 08:08 AM
dcook442's Avatar
I'll post a pic of the stuff I use later today. It's not exact, but it's real close and will last forever
Old Nov 24, 2021 | 08:12 AM
dcook442's Avatar
Old Nov 24, 2021 | 03:56 PM
paint thanks i have already shot it with epoxy and it is in primer now just waiting for a color thats close would be great. Finally just finishing this car up.almost all done 67 442 rag loaded with option Black on black top Yellow Sport bench seats with Headrest power seat power antenna power windows tinted glass ccc breather uhv ignition posi rear tilt tach gauges ssi wheel frame off just painted it Really rare interior as yellow was discontinued owner had to call gm to order the yellow Special C where interior color is supposed to be on trim tag Documented through gm Canada
Old Nov 26, 2021 | 02:04 PM
dcook442's Avatar
This is what I use. Reduced 1:1 and then 5% activator.
Old Nov 26, 2021 | 02:13 PM
67 paint
67 paint thank you so much will see what i can do with the paint number Al
natedrag
Feb 9, 2018 04:57 AM
Zr1bandit
Oct 7, 2013 12:13 PM
hurst68olds
Paint
Dec 31, 2010 04:19 AM
squirell
Nov 8, 2009 04:38 PM
SX455
Feb 1, 2007 06:57 PM
