Interior colors - poly vs. non poly etc.
Old Oct 28, 2019 | 11:10 AM
gratsoy's Avatar
Given this photo, I am in need of some help
What is the difference between the Dark Green and Dark Green poly colours? I am thinking Poly = metallic, but even then, where do I find information on which part is metallic and which isnt?
Is paint covered in the assembly manual?
Old Oct 28, 2019 | 11:26 AM
Daiv8or's Avatar
I believe the "poly" refers to polyurethane paint, usually a two part paint system. I assume the other number is either for an enamel, or lacquer. They would be the same color.
Old Oct 28, 2019 | 11:40 AM
Sorry, no. In Oldsmospeak, "poly" was metallic. Look at the paint chips. Only the metallics are called "poly". Polyurethane paint wasn't used by Olds at that time. Paints were primarily lacquer, though there were some uses of enamel.
To the OP's question, you need the Product Information Manual (aka Assembly Manual) for your year and model. The first section included pages that tell you exactly what parts of the interior were painted with which specific paint formula for each interior trim code.
Old Oct 28, 2019 | 11:46 AM
Here is an example of one of the several pages of interior paint colors and locations from the 1965 A-body PIM.
Old Oct 29, 2019 | 08:47 AM
gratsoy's Avatar
Good call. I looked at my assembly manual (1970) - group 0 has this info.
In fact, Page 37 uses the word metallic instead of poly
Page 43 lists which pieces get which colour
Old Oct 29, 2019 | 09:09 AM
And just to follow up on this, "poly" was short for "polychromatic", which is what they called metallic paints in the 1960s.
Old Oct 29, 2019 | 10:36 AM
Lonnies Performance's Avatar
Good info... I always knew "Poly" meant metallic but never knew why.
Old Oct 29, 2019 | 06:59 PM
Daiv8or's Avatar
Good to know. Never heard that term before with regards to paint.
gratsoy
Paint
Oct 20, 2018 06:30 AM
1970442
Jan 14, 2014 06:44 PM
ithaca4me
Oct 16, 2010 12:35 PM
B-Mann
Paint
Jul 7, 2009 09:07 PM
1968 42
Apr 12, 2008 07:32 PM
