Blending paint, laquer question
Old Mar 30, 2021 | 04:29 PM
Andy's Avatar
I have a 70 442 that was painted 30 years ago in lacquer with a clear lacquer on top. I love the patina and would like to fix the rust out on lower fenders, then blend or paint below the stripe to tru and match the paint. The question is can you still get laquer and if not can you blend base clear onto lacquer without paint reaction? Need expert advice on this please..Thanks, Andy
Old Mar 30, 2021 | 05:11 PM
Oldsmaniac's Avatar
Yes Lacquer is available color matched to factory colors... I use TCP Global and their Auto Color Library. They ship UPS
Old Mar 30, 2021 | 05:17 PM
Andy's Avatar
in your opinion whatsthe chances of it matching correctly? Would the stripe be enough of a break to stop the eye from noticing small color difference ?
Old Mar 30, 2021 | 06:00 PM
dc2x4drvr's Avatar
Well, even with a perfect match, where would the ‘break’ be, up to the stripe? Anyhow, by the time all the rust is repaired, you’re looking at painting the fender. just my .o2
Old Mar 30, 2021 | 06:09 PM
Andy's Avatar
yes I was hoping to paint below the stripe, stripe being the break..maybe I am being to optimistic..
Old Mar 30, 2021 | 06:31 PM
Lonnies Performance's Avatar
The risk is mail order lacquer has a slim chance of matching 30yr. old paint.
Yes, you can repair with base/clear ((with a lot more options to adjust the color) & it looks like you can get by with using the stripe for a cut line with only a slight blend at the front edge or to clear the wheel opening lip also.
Old Mar 31, 2021 | 07:09 AM
Andy's Avatar
So the base coat sprayed on the lacquer to blend will not lift or effect the current paint?
Old Apr 1, 2021 | 06:00 AM
chopolds's Avatar
You can do base over lacquer, but it is still better to use lacquer all the way through. And lacquer is very easy to blend off, even the clear, unlike modern urethane clears.
Old Jan 20, 2023 | 08:19 PM
FStanley's Avatar
Great job!
not sure if anyone mentioned. I n the old days there was a Ditzler(PPG) blender for acrylic lacquer. Did a great job..
I saw this Spraymax blender, has any used this?? if so results and what type paint(s)??
https://www.spraymax.com/en/products...blender-clear/
dfire25
Dec 19, 2012 10:11 AM
Eddie Hansen
Paint
15
Jun 12, 2012 06:13 AM
Del70
Aug 21, 2011 05:43 AM
jensenracing77
Paint
Aug 2, 2009 05:17 AM
scrappie
Mar 27, 2007 08:08 PM
