Best way to get the correct color through codes
Old Jun 11, 2019 | 08:21 AM
Sicklyscott's Avatar
I've read a bit about the older paint pigments no longer being available. I have different paint codes from different manufactures through PaintRef.com. Companies they have codes for:
- Ditzler PPG
- Dupont
- Acme Rogers
- RM BASF
- Sherwin Williams
Have any of these proven to be more consistent with the original color than the rest?
-S
Old Jun 12, 2019 | 04:58 AM
Brad J.'s Avatar
I'm not much help on this new stuff but I did have trouble getting Jade Gold for a 68' 442. Dupont discontinued the tints and PPG didn't show anything. I had to use Nason which is a lower line of Dupont. I hate cheap paint so I tried to convert it Standox and PPG from the Nason sprayout and nothing looked as correct as the Nason. So cheap base with a great clear over it will be fine.
We have finishmaster and they are the only ones left around us. They don't seem to be much help in finding colors. If it's not in the computer then your SOL.
But.. discontinued tints is a problem. They eliminate ones they don't sell much of anymore.
Old Jun 16, 2019 | 12:16 PM
'72ROCKET's Avatar
Hi, new member. I have a question. I am restoring a 1972 Cutlass S, Radiant Green colour and we are at the painting as it out of the body shop. Radiant green, two stage is what is going to happen and samples the paint shop has made has significant fine metal flake. Does Radiant Green Have Metal Flake? The last paint done on the car had no metal flake, it had two different layers of paint and was taken down to bare metal... The painter wants to paint it using this metal flake green. The question is , is Radiant Green to have metal flake? I have an old pic before it went to body a year ago.
1972 Cutlass S
gratsoy
Paint
Oct 20, 2018 06:30 AM
scottyr33
Aug 7, 2017 08:09 PM
RROLDSX
Paint
Feb 9, 2013 02:47 PM
Stevoreno
Oct 4, 2011 11:41 AM
Del70
Aug 21, 2011 05:43 AM
