1969 442 w32
1969 442 w32
Can someone verify if this is the correct trunk stripe for a 1969 442 W32
Are there any factory drawings showing correct positioning and stripe size
Joe
Joe
See Manual Section 1-4, page 402, of the '69 Cutlass/4-4-2 assembly manual. The stripe across the bottom of the trunk lid is .4" wide, the bottom of the stripe being .56" above the trim piece across the bottom of the trunk. The stripe around the tail lights is .2" wide and follows a path of .12" above the edge of the trunk lid & quarter.
Randy C.
Randy C.
It should be the same, whether or not it is a W32. Either the W42 option (hood stripes) or the Y73 option (hood dual pin stripes) should have the same striping around the back end from the factory. Your pic is the first time I've ever seen a dual pin stripe across the bottom of the trunk lid. I would say that it is someone's special touch!
Randy C.
Randy C.
I've looked at several original 1969 W32 cars. The stripe on the white car's trunk is the stock 442 stripe. There are MANY W32 clones around, including some really well known W32 cars (like the blue 'vert). There are many that owners say they bought new or 1 year old, but have no paperwork. MANY that the numbers don't match because the engine was blown early, or the rear, or the tranny, or whatever. W/o papers, I have to say these are among the hardest cars to prove authenticity. The original W32 cars I've seen all seem to have one thing in common...the trunk lid is uniquely striped differently than a 442. Why? I don't know. Are they all like that? I don't know. It's really the only unique thing I've noticed about W32 cars in the 20-25 years I've been looking at them!
I'm wondering if there something more to look for to verify?
Is there a registry, or a documented VIN number listing?
Very interesting, That's exactly what we've seen searching around. the double stripe on the white car above could possibly be correct, or maybe someone custom rendition.
From your experience, what have you seen to be the most common truck stripe?
We only want to apply the stripe once.
Joe
Ok...I just looked at the white car stripe again and what I wrote before is wrong...I apologize! That is NOT the stock 69 442 stripe on the trunk shown. What Randy said is correct, that's how my 442 is striped. The W32's I've seen that I believe are real all have a double stripe similar ( I don't remember exactly) to the stripe on the car shown. That car doesn't seem to have the chrome lip trim, which I'm unsure about, but I think should be there. There is a W32 here in MA (ID mistertwister?) owned by a club friend named Chris. There is a nice restored sable W32 'vert from I think Canada that often goes to the Nats. I spoke to the restorer about that stripe. There are other things to look for, but when you find something not right, there is typically an excuse. Many of these cars were cloned a long time ago, and are accepted as real now. Once a car gets in a magazine as a W32 everybody swears it's real. Nobody wants to take responsibility for cloning it. The white car with the red interior looks like a car that was at shows in MA + CT a few years ago. I think it's changed hands several times since then. It's well known that some of the cars in Hemmings Muscle Machines were rumored to be clones.
Hi Joe,
I have the sense this thread has gone somewhat awry. First, I thought the rear stripe for the '69 4-4-2 was the same, whether it was a regular 4-4-2, a W-30, or a W-32. That's the stripe you just pictured and that's the stripe that I have on my "regular" '69 4-4-2 (pictured below). It's apparent that perhaps the W-32 used a slightly different type of striping across the bottom of the trunk lid, as verified by Mrolds69. I've never seen a W-32 before so I just don't know. And, for that matter, now I don't even know about the W-30! But, for just your standard 4-4-2 with either the W42 "hood special painting" of the Y73 "hood paint stripe" options, the picture you show above, and the picture I show below, are correct! I apologize if I have mislead anyone here!
Randy C.
Randy C.
What I'm reading is that no one really knows for sure whether it is a single stripe as per the assembly manual or something different for the W32 model.
With the limited production of this option code, knowing for definite sure would be like finding a needle in the hay stack, UNLESS, someone has a picture from the early '70s - just putting it out there.
Joe
Joe
I don't see why the W32 would receive a different stripe - it's a W-Machine.
Have you looked here?
https://www.gmheritagecenter.com/doc...2_Info_Kit.pdf
I agree with Diego. Unless there is definitive proof that the W-32 (or any other W car) used a different rear striping than what is outlined in the assembly manual, I'd tend to believe anything else is someone's creative artwork. The dual stripe across the bottom might be factory, but I would need solid proof of that.
Randy C.
Randy C.
I have seen several original paint 69 w cars with the double stripe on the trunk, also 69 442 post cars both my 69 442 post cars came from the factory with the double stripe on the trunk.I have also seen other original paint 69 442 post cars with the double stripe. Greg
Interesting information, Thanks Diego
The exert from the letter put out by the Public Relations department on the W32 - "...the dual stripe hood paint treatment (W42) is optional," It makes no reference to a dual stripe on the trunk lid, but my guess would be if you have W42 option, likely the dual stripe was carried into the trunk stripe.
This particular car has only a single stripe on the hood, so we're going with a single on the trunk.
Thank You to all that have provided input.
Joe
Joe
There is no paint stripe option on a 442 or W car that has a single stripe on the hood all W cars should have the double stripe on the deck lid except W 31
W30 and W31 cars had W42 stripes as standard; initially, this was true for the W32 but later amended when it finally hit production (I have the marketing bulletin but it's lost in my computer somewhere).
From aretubj:
The optional stripe for the 442 was what was called the Y73 Ralley stripe which was a dual pin stripe outlining the hood. HumpsAll original paint W30 and W32 cars I have seen and they are several have the double stripe on the deck Lid as do 442 post cars.regular 442s had the single deck Lid stripe. Greg
What I was saying here,is that there is no single stripe on the hood,even the w 42 stripe had an outline around the stripe,which would still be a double stripe,and that all W cars had the double pin stripe on the trunk as did all post cars,standard 442s had one single constant stripe on the deck lid. I have never seen a standard 442 with the W42 stripe that was original paint. Greg
I noticed in that factory statement, that they got the 15x7" wheels and F60x15 tires, not convinced that they came that way. '69 H/O was the only one that got that tire and wheel combo. Anybody have original paperwork showing that combo?
There you go,just because it's on a piece of paper doesn't mean it's gospel.I have been working on these cars since they were new,also restoring them. How many of these cars have you restored ,worked on,or even seen in original paint Diego? Greg
But please spare me and others the "there you go" condescension. A number of us are interested in the as-delivered specs for W32 cars, and if you can't include some evidence to back up your beliefs, then what good is it?
FWIW, I know nothing about the trunk pinstripe other than what I posted from the info packet of the GMHC. Could have there been a running change? Sure, it happened all the time, but I don't believe the W32 or any other W-Machine received a different trunk pinstripe.
FWIW,I don't think you know anything besides what you read. I have been repairing,restoring, buying and selling these cars for over 45 years. Can you make that claim? Talk about condicending,I was most likely working on these cars when you were in diapers. Greg
#31
Uhhh...I would have to totally agree with this Diego! Just because you wrote a book, doesn't make you the resident expert for all musclecars. In writing is nifty, but if you wrote a book, you should know there are a LOT of oddities in the musclecar world. I've got a lot of info here, but I'm too lazy to sift through it. I know what I've seen, I know what an original paint car looks like. The truth is...I was hesitant to mention the double stripe at all, because it was one of the few things I know (and others don't) to spot one.
#32
When it comes to these cars,never say never and keep an open mind. IE,I bought an original 68 Chevelle SS car from the original owner. I sold it to a 68 expert from Chicago and when he saw the pictures I sent,he said the car had the wrong wheels. It had the spoke type 69 SS wheels instead of the 68 rally wheels he said the car came with. I had to go back to the guy I bought the car from to get the original AM/FM radio and I asked him about the wheels being on the car new. He went into his house and brought back a picture of his Dad handing him the keys to the car when he returned from Vietnam. The car had the window sticker still in the window and the SS style wheels were on the car. When the expert from Chicago came to get the car,I asked him was he sure about the wheel deal,he was adamant to the point of almost being obnoxious about it. I had borrowed the picture from the original owner and showed it to the expert and he changed his attitude real quick. He said he had never seen that before and this is why I say never say never.
#33
Then you should post it.
#34
I gotta apologize to aretubj, who started this thread looking for information but several people decided to make it about me.
I've been on the Internet starting around '97 and, since then, I've had douchebag Baby Boomers tell me, "What do you know? You weren't even alive then!" It still happens, almost 20 years later.
But facts have a way of creeping into the conversation and shutting people up.
If you're "too lazy to sift through" your info or are "not proficient on a computer," then what good are you? Only the inexperienced, if not fools, are going to believe some guy just because he has "been working on these cars since they were new,also restoring them." [sic]
I'd say my Internet "home" is a Mopar site. There's a lot of knowledgeable people there, and you generally can count on the knowledge base to find the proper answer, if not be several degrees closer to one. Can the Oldsmobile community claim the same type of home? I don't think so - the mindless egocentric bickering on this site constantly fails to sustain a collective quest for information. There's been some intelligent people here who have been driven away by the drivel that has gone on in the past....and apparently continues. We're only so lucky to maintain the presence of the likes of Joe, Steve, Mike, and ????? Putting everyone's head together and sharing information is the way to elevate the brand to new heights.
Yet then you wonder why Oldsmobile cars and parts are not in demand in comparison to Brand X.
#37
#38
the OP was given correct spot on info,YOU decided to make it about YOU. The only thing you gave him was a paper shuffle never answering his original question.........is this stripe correct. The above is a typical millenial rant how could someone who has been there done that lived it know more than me? I looked it all up! Greg
crystal59
July 6th, 2023 04:39 PM
