1967 cutlass bezels
Old Oct 14, 2025 | 02:24 PM
Lancealars's Avatar
1967 cutlass bezels
Since i have the 2 bezels off, I thought I would paint the black insides. Im NOT a painter or have any experience. Any tips on kind/brand of paint, color, pre sanding? Taping? Etc???
Old Oct 14, 2025 | 04:29 PM
Giftman23's Avatar
I use 1” mask tape and carefully work around the outer edges of the black as close as possible. Doesn’t have to be perfect as you can clean up with some quad 0 steel wool after painting and removing tape. Anyway, mask off all the additional metal, scuff the black with some scotchbrite, then take a rag with a little lacquer thinner and prep the areas to be painted. I use any old flat black, not sure if that is factory correct but works well and looks fine.
Old Oct 14, 2025 | 04:35 PM
Lancealars's Avatar
Thanks Giftman! Exaclty what I was looking for. 👌
Old Oct 14, 2025 | 04:37 PM
fleming442's Avatar
I used 1/4" fine line tape and Eastwood Cassis semi-gloss. Maybe not correct, but it looks good. Don't forget the screw heads!
Painted Desert National Park- 10/24
Old Oct 14, 2025 | 04:40 PM
Lancealars's Avatar
Yes! Good point Fleming. Damn I would have forgotten until i reinstalled. They say when you get older the first thing to go is memory. I forget what was second.
lol
Old Oct 14, 2025 | 05:09 PM
Lancealars's Avatar
Fleming, why are the inside headlamps yellow? Looks cool
Old Oct 14, 2025 | 06:33 PM
fleming442's Avatar
Honestly, I don't know why the yellow lights. It was a 60s thing. Mine are actually functional fog lights on a separate circuit. The outer/low beam holes have Hella H4 conversions with OSRAM bulbs. I think you can get Holley Retro brights in yellow, but they're expensive. Some just paint them with tinted clear.
Any of you fossils want to explain the yellow light thing? 😁
rectifier
Jan 4, 2024 05:08 PM
Harry Smith
Jan 4, 2024 01:44 AM
67abody
May 5, 2019 06:44 PM
seanoo
Nov 4, 2017 08:06 AM
mannyf85
Jun 23, 2014 07:26 AM
