Looking for water hoses F-85
Old Jun 2, 2020 | 06:11 AM
Oldsmoswede's Avatar
Hi!
Looking for new water/cooling hoses to F-85 1963.
Anyone know where to find? (if its possible?)
Have done some googling without success.
Patricularly the one going from front of engine(above) to heater core on passenger side.
Old Jun 2, 2020 | 07:55 AM
Have you been to your local auto parts store?
Old Jun 2, 2020 | 07:57 AM
jaunty75's Avatar
Instead of googling, you need to visit the website of actual parts vendors. Rockauto.com shows availability of both the upper and lower radiator hoses for your car. Some are specific to your car, others are universal hoses that can be bent to fit your car.
As far as heater hoses, those are not normally pre-made. Just measure the length you need and the diameter of the fittings it attaches to and buy that length and inside diameter of heater hose from the local auto parts store.
Old Jun 2, 2020 | 08:41 AM
He's primarily asking about the molded heater hoses. RockAuto does not list those. No one sells them. I had to use generic heater hose.
Old Jun 2, 2020 | 10:28 AM
So I guess I have to buy som pieces and add them together with some metal pipes?
Old Jun 2, 2020 | 10:30 AM
jaunty75's Avatar
I don't think you'll need metal pipes. Just need to buy a length of flexible hose for the radiator or heater hose for the heater core and cut it to the length you need, if necessary.
Old Jun 2, 2020 | 11:20 AM
jensenracing77's Avatar
If I can remember, I have some part numbers for replacement hoses that fit really well. I will have to look tonight for them.
Old Jun 2, 2020 | 11:26 AM
Looks like one of them is a gates part number 21860. The other number I have I believe is Jetfire only.
Old Jun 2, 2020 | 01:17 PM
That sounds exciting 😮
Part number 21860 seems to be som other location than my need #1. I will try to locate that one, I might need that as well. Thanks!
I hope you find the other number also 👍
Old Jun 2, 2020 | 01:23 PM
Ok I will look at it if I dont find any molded one that fits, thanks!
It might be a bit tricky without folding it, there’re two 90degrees bends just before the heater core.
Old Jun 2, 2020 | 04:37 PM
Gates 19604... Does this look like what you need?
https://www.amazon.in/Gates-19604-He.../dp/B000C2S8RI
Old Jun 2, 2020 | 10:33 PM
That might be a part of it, if I have to make one by my self with a lengthening joint.
I will try to insert a photo where I have marked it with a red line...
Old Jun 3, 2020 | 05:19 AM
OK, I forgot that the Cutlass and F-85 use a rubber hose this full length. On the Jetfire, this is a metal pipe and this S hose fits that part from the back of the metal pipe.
Old Jun 5, 2020 | 06:45 AM
I was thinking the same solution actually, why couldn’t it be a steel pipe with rubber ends instead? Maybe I will do same design as on your Jetfire then.
Is it made of stainless steel?
Old Jun 5, 2020 | 07:23 AM
Just be sure that the rubber sections are long enough to provide flexibility for engine vibration. You don't want to be flexing the hose fittings on the heater core. That won't end well.
Old Jun 5, 2020 | 08:10 AM
It is just mild steel. Actually, many of them rust out over the years. You could use the S hose I posted above and from that go to pipe. That would be long enough to be safe. The front side just goes to the water pump so no worries there, any elbow rubber hose would work there.
Old Jun 5, 2020 | 08:59 AM
Ok thank you for your advices joe and jensen 👍👍
Ste981
May 2, 2018 11:45 PM
Guillaume
Sep 4, 2017 01:00 PM
kdub
May 3, 2016 10:48 PM
My62F85
Sep 29, 2014 11:32 AM
cutlass66
Apr 18, 2006 11:11 AM
