Help ! Car goes into full acceleration with no gas’
Old Jul 26, 2019 | 09:05 PM
jhawkthebeast's Avatar
Hey everyone I own a 72 cutlass and I was reversing out of a gas station when my gas pedal felt like it was stuck to the floor and then I started full accelerating in reverse so I mashed the brakes but I have a brake boost leak so it will still accelerate I put it in drive and then cut it off the pedal is like loose and I don’t know what the problem is. Also I got a new transmission put in but I don’t think it is relevant because it was working fine. Please help me
Old Jul 26, 2019 | 09:09 PM
There should be a spring on the side of the carb where the throttle cable connects to the carb linkage. Your spring likely came loose or broke.
Old Jul 26, 2019 | 09:35 PM
Disconnect the throttle linkage and make sure the carburetor and the cable moves freely. There is also a detent cable that runs from the accelerator pedal to the trans if you have T350.
Old Jul 26, 2019 | 11:47 PM
I have a new tci t-350 cuz the other one blew out ( original very old high mileage plus teenage car enthusiast)
Old Jul 27, 2019 | 01:51 AM
^^^^This. The accelerator cable is a braided steel cable inside a plastic sheath. The individual strands of the braided cable eventually break due to wear, which creates sharp edges that dig into the inside of the plastic sheath. This causes the cable to bind, jamming the throttle. I've had this happen on two different vehicles in the last 45 years. The fact that the pedal is loose confirms this. Replace the cable.
Old Jul 27, 2019 | 09:53 AM
Okay thanks! How do I go about replacing the cable?
Old Jul 27, 2019 | 10:43 AM
I fixed it but i don’t know how
I just pushed the throttle control from the carb a few times and then messed with the throttle cable down at the pedal and it works now. I drove her in the neighborhood to see if she was good and she is although she’s slipping at like 30-40 mph not hard but noticeable. And fluid is full and good. Although there’s a little leftover fluid from the blown tranny I’m thinking if I just keep changing the fluid eventually there will be no more of that black burnt trans fluid. Thanks everyone!
Old Jul 27, 2019 | 01:10 PM
If its the cable, the problem will return at the most inopportune time. You may want to rethink your strategy.
kbdecatur
May 3, 2019 04:58 PM
brown7373
Sep 23, 2017 08:07 PM
1969CutlassSBlue
Dec 28, 2016 09:16 AM
mcox8051
Jun 25, 2015 11:11 AM
yeahbuddy
Apr 4, 2012 09:54 AM
