What parts to buy
Old September 14th, 2017, 08:34 PM
major noob
billmerbach's Avatar
What parts to buy
I placed this in other cause I wasn't really sure where it would fit in. Here's my dilemma.....
i need to know what parts I should get should I go old school or ramp it up with some higher end stock parts
I need plugs wires brakes and oil
what would y'all recommend for my 73 455 for the basic tune up but for quality include part numbers if you can please
thanks yall
bill
billmerbach is offline
Old September 14th, 2017, 09:11 PM
Proud Viet Nam Veteran
redoldsman's Avatar
Keep it basic Bill. You will be wasting money on the high end stuff. Use a good grade of oil with zinc in it (Valvoline Racing Oil is a good one) and a good oil filter like Wix or NAPA Gold. Price your plugs, wires, points and condenser at RockAuto. Be sure and check the shipping because it can offset the cheaper price.
redoldsman is online now
Old September 15th, 2017, 04:38 AM
As Glen suggested on the oil. Napa has good quality points and condenser, buy separate not the uniset. Some quality 7mm wires, new cap, and rotor. Plain old A/C, Autolite, or NGK spark plugs. Gap all the plugs, make sure you set your dwell first, and then set timing. Stock settings will work well.
Before buying a bunch of stuff for your brakes, do a thorough inspection and replace just the worn or leaking parts, again Napa brand parts will work well. When doing the fronts, clean and inspect your wheel bearings and races, repack with wheel bearing grease.
oldcutlass is offline
Old September 15th, 2017, 02:20 PM
redoldsman's Avatar
One thing you do need to buy for your brakes is new hoses for the front and the one for the rear. Trust us on this one.
Old September 15th, 2017, 08:45 PM
Funkwagon455's Avatar
One think you do need to buy for your brakes is new hoses for the front and the one for the rear. Trust us on this one.
This is some very cheap insurance,,, $35 hoses, $6 fluid.. Good advise.
Funkwagon455 is offline
Old September 18th, 2017, 08:10 PM
major noob
Will do I work at advance so hopefully I can get this stuff cheap the car has 107 thousand on it I need new valve cover gaskets and. Dipstick tube since this one is missing
Old September 19th, 2017, 05:02 PM
Olds Fever
CRUZN 66's Avatar
Oil indicator guide tube is part number 401357... I have NOS tubes available for $45 each plus S/H based on location...
CRUZN 66 is offline
71OldsCool
October 29th, 2016 08:35 AM
fuelbp
March 2nd, 2016 07:54 AM
chip-powell
February 1st, 2016 03:39 PM
Curts1970cutlass
October 27th, 2015 04:36 PM
lsutigers93
June 22nd, 2014 07:09 AM
Quick Reply: What parts to buy
