AC compressor reseal
Old Nov 1, 2016 | 02:01 PM
My2nd 69 442's Avatar
Good afternoon all
I'm in process of rebuilding my Frigidaire AC compressor for my 69 442 and would like your help locating a seal kit for rebuild and any help location instructions for doing this. I'm presently using my CSM but the illustrations are mostly unreadable. I am having my hoses rebuilt at the same time
All help greatly appreciated
Jerry
Old Nov 1, 2016 | 05:12 PM
jensenracing77's Avatar
You may contact Ray (NDERISE). He has rebuilt them and I believe he knows were to get them.
Old Nov 1, 2016 | 05:55 PM
jensenracing77
I appreciate your reply.
Would you please give me contact for Ray. As I search for his contact info, I do not find that name here on CO, or else I just don't know how to properly search for him.
Jerry
Old Nov 1, 2016 | 06:10 PM
This should get you there...
https://classicoldsmobile.com/forums...s/nderise.html
Old Nov 1, 2016 | 06:30 PM
Thanks so much. I have sent him a PM
Old Nov 2, 2016 | 06:39 AM
oddball's Avatar
banny here is also a knowledgeable A/C guy. The ceramic shaft seals and general seal kits are available at A/C specialist suppliers, such as ackits.com. Note that it takes a handful of special tools to R&R the shaft seal. Those are typically available at suppliers or on ebay. There are guides out there on the internet, and a couple of good videos on youtube, just look for "a6 compressor rebuild".
The problem doing it at home will be telling whether or not there's damage to hard parts and any need to replace rings or resurface pistons/bores. I took one A6 apart for kicks, and removing the oil pickup certainly is tricky.
Old Nov 3, 2016 | 05:55 PM
Jensenracing77
Thank you for passing along the contact info for Ray(NDERISE).
I just now spoke with him and he was very helpful. I feel a lot better after talking to him as I may not have any real problem with my compressor. His advice will allow mw to reservice the system after I get my lines back from repair and hope for the best.
Thank you to Ray also. you were a big help to me.
Jerry
Old Nov 4, 2016 | 05:45 PM
Ozzie's Avatar
Originally Posted by my2nd 69 442
good afternoon all
i'm in process of rebuilding my frigidaire ac compressor for my 69 442 and would like your help locating a seal kit for rebuild and any help location instructions for doing this. I'm presently using my csm but the illustrations are mostly unreadable. I am having my hoses rebuilt at the same time
all help greatly appreciated
jerry
napa 5493 $21.49
Old Nov 4, 2016 | 08:52 PM
I believe that I have my AC system mostly under control. Compressor is wait and see, hoses being rebuilt, now just need to find an original style dryer if they are to be found.
Thanks for your help so far. I'll update if/when I find the dryer.
Old Nov 5, 2016 | 12:18 AM
Ozzie's Avatar
Four Seasons 33211 $8.75 + shipping
http://www.rockauto.com/en/catalog/o...cid+v8,1213467
or
NAPA TEM 208508 $17.49 + tax
Old Nov 6, 2016 | 01:06 PM
Do any of you AC gurus have a picture of an original AC dryer for a 69 442? Dryers that will fit do not look like the dryer that is on my car.
Anyone that may have a source for an original style dryer your help will be greatly appreciated
Old Nov 6, 2016 | 05:32 PM
The only way to get the original style is to send yours to Classic Auto Air and have them rebuild it. Nobody makes one like the original any more. Classic Auto Air will cut them apart and replace the filter and weld them back together.
Old Nov 6, 2016 | 05:37 PM
My issue with this is that I don't know if mine is stock to the vehicle. I would like to see what an original one looks like for a 69 442.
Old Nov 6, 2016 | 07:35 PM
Ozzie's Avatar
I'll bet that you'll have difficulty getting a photo that is "guaranteed" original. If there was an original owner out there that had never changed it in 47 years or saved the original it would be possible. I have a '65 but it's a different part number. The group is 9.195. The part is 3046236. Supposedly the attached photos are of a 3012944 which was used on the same year Corvette and is expected to interchange with 3046236 (but may not be exact?). I don't know what accounts for the difference; internal, external, or both. 3046236 supposedly was used from 1968-72 on the Olds (but not Toronado). The expanded search years may help some.
Old Nov 6, 2016 | 07:47 PM
Those photos look about right - in '69 the receiver had a sight glass, which the new ones likely do not have.
Remember that if you find a sealed original, it will have dessicant compatible with R12 but not R134.
If it's not sealed, it's garbage, unless you want a core to be rebuilt.
Old Nov 6, 2016 | 08:12 PM
I found this item @ Supercars Unlimited Item #: 22-098
Description:
1968, 1969, 1970, 1971, 1972 Air Conditioning Drier
This looks very similar to what I currently have installed and similar to the pics that Ozzie posted.
I stripped the paint off mine and it looks the same to me.
Now to find a place for an estimate to overhaul mine. With shipping, I don't believe I can have mine overhauled for the price of Supercars new price
Thanks for your input
Jerry
Old Nov 6, 2016 | 08:53 PM
Ozzie's Avatar
Mine doesn't have the pronounced ribs at the ends of the flats or the fitting on the outlet, but again it's a '65 with a different part number from yours.
Old Nov 13, 2016 | 08:12 AM
banny's Avatar
The ribs the you see are the "stack of dimes" look when its tig welded. The fitting you see is just a basically just a plastic cap.
Old Nov 13, 2016 | 08:14 AM
banny's Avatar
Description:
Jerry
I believe I may have a new one like the one from Supercars Unlimited. You can have it for $40 plus the ride
Old Nov 13, 2016 | 08:21 AM
banny's Avatar
Old Air Products sells rebuilt driers or offers the rebuild service.
http://www.oldairproducts.com/catalo...reme&Year=1969
Old Apr 24, 2017 | 02:22 PM
Hello all
I hopefully have completed my AC work for my 69 442 today.
I have rebuilt the A6 compressor, had all hoses rebuilt and replaced the dryer.
Over the weekend I pressure checked the system with nitrogen and Vacuumed the system for a good 24 hrs down to 29.9 HG and today had the system serviced with R12.
All seems to work great with air temp at the vent @ 36* (OAT @ 92*)
I still need to adjust the RPM up a little bit. With AC on idle drops to aprox 450 -500 RPM and wants to die. At AC shop I turned idle up so it idles a little high now and too high with AC off. Hopefully I dont run into any other AC related issues and system keeps blowing cold.
I appreciate all the help and suggestions from all
Jerry
ThomasAlicea
Aug 30, 2014 12:03 AM
fv64olds98
Drivetrain/Differentials
May 10, 2013 06:47 AM
1FSTLS1
Dec 28, 2007 07:45 PM
2 door cut
May 14, 2007 07:52 AM
jaco
Jan 5, 2007 08:57 PM
