Other Oldsmobiles Anything not listed above, such as F-85 (1961-1963), Firenza (1982-1988), Starfire (1961-66 and 1975-80), Omega, etc.
Spark
Old Feb 27, 2012 | 03:30 PM
Dokks74's Avatar
Spark
I finally got my Omega to run, but it's running a little rough. After some under hood time, I found 2 plugs were fouled and were not firing. Turns out someone had the plug wires wrong. I put in new plugs and wires and now have no spark. I have power to the distributor...I added a new ignition module and rotor.... Still no spark.... I added a new cap and coil...Still no spark....The only thing I haven't replaced is the electric pick-up in the distributor. Going to pull the distributor tomorrow, and replace the pick-up. If it still doesn't run, I have a 1974 Omega, with a great body, 350/350 with a big cam for sale!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!..
Old Feb 28, 2012 | 01:25 PM
Dokks74's Avatar
Pulled the distributor and bench-tested it. Plenty of spark. I also have spark to the distributor while cranking the engine... Anyone??.. I'm going to check #1 position on compression stroke with the position on the rotor tomorrow.
Old Feb 28, 2012 | 02:24 PM
Engines need air, fuel, and spark to run. Its got to be 1 of those 3 thats missing.
Old Feb 28, 2012 | 04:10 PM
Dokks74's Avatar
It has gas,plugs are wet, and you can smell it...Plenty of air...No spark.
bonesbmx
Jun 2, 2020 02:10 PM
ChrisM
Mar 7, 2009 08:07 PM
ChrisM
Nov 1, 2007 02:23 PM
66starfire
Jan 3, 2007 10:31 AM
<james.reinhart@detroitdie>
Jul 24, 2004 09:34 PM
