Other Oldsmobiles Anything not listed above, such as F-85 (1961-1963), Firenza (1982-1988), Starfire (1961-66 and 1975-80), Omega, etc.
Question about installing a Gas Tank on an F-85
Old Oct 13, 2007 | 09:48 AM
Wil Lopez's Avatar
I am working on my 62 F-85 installing a gas tank, and have run into a problem. The tank has two lines. One is the feeder for the gas (3/8 hose line), and the other is 1/4 inch hose line off of the gas sending unit. What is the 1/4 one for? I bought the tank from a gentlemen who had taken it out of a two door convertible (same year). My car is a 4 door sedan. Any answers to what the 1/4 hose is for, and where I am supposed to connect it to. I have to make this work somehow, because it was very difficult to find a tank for this year.
Old Oct 13, 2007 | 11:56 AM
Hmmm... well, since the guy said he got it off of a 62 convertible I guess it couldn't be a line for a charcoal canister. I have no idea what it would be for.
Old Oct 14, 2007 | 03:59 AM
ozoneblue's Avatar
I would use this hose as a vent & place it higher than rear end to avoid water. That year may not have had a vented cap,There should be some type of check valve for the end of it
Old Oct 20, 2007 | 10:13 PM
59-59-59's Avatar
Isnt the 1/4 tube just a vent? There should be some type of bendable clip mounted on the underside of the body to hold it in place
Old Jan 16, 2008 | 05:24 AM
Barneyo's Avatar
Just had a tank replaced on my 62 F-85 convertible.
The 1/4" metal line coming out of the sending unit is the line that carries
gas up front to the fuel pump then the carb. (It follows a groove in the
top of the tank)
The larger hose that comes out of the tank near the filler pipe is the line
that allows air out of the tank when you are pumping gas. It connects to
the 3/8 pipe fitting that is about 8" down from the top of the filler pipe.
BTW According to my shop manual 2Dr/4Dr bodies all use same tank...
the only different tank is for the station wagon - I guess because the
tank sets farther back from where the filler door is on the body thus a
longer filler pipe (?) And I would guess the tank itself is same and the
repair shop coud swap the filler pipe from a bad tank to a good one if
necessary...
joemo
Sep 21, 2022 04:47 AM
1carsick
Oct 17, 2012 09:10 AM
68442S
Jul 8, 2012 09:07 PM
Texas442
Jan 30, 2012 05:36 PM
OLD SKL 69
Jan 21, 2008 09:51 PM
