Other Oldsmobiles Anything not listed above, such as F-85 (1961-1963), Firenza (1982-1988), Starfire (1961-66 and 1975-80), Omega, etc.
PCV Setup 64 Starfire
Old Mar 31, 2019 | 12:31 PM
jlw35's Avatar
Would someone confirm that on a '64 Starfire, that the tube on the snorkel to the PCV is aluminum and not rubber?
Pretty sure that it is, if so, trying to source it.
Jeff
Old Mar 31, 2019 | 05:57 PM
Charlie Jones's Avatar
Phantom Phixer
Every 63 or 64 I have seen that has a four barrel has a rubber tube .
Yes , it is hard to find a good one . And I don't think anyone is re-producing them .
Two barrel jobs had a metal tube but were completely different . Will not fit .
Old Apr 1, 2019 | 06:25 AM
jlw35's Avatar
Thank you Charlie.
Jeff
Old Apr 1, 2019 | 07:29 AM
Lonnies Performance's Avatar
My 64 has a metal tube. Not sure if steel or aluminum, I can check tonight.
Old Apr 1, 2019 | 08:31 AM
jlw35's Avatar
That's a beautiful engine bay!
Thanks for the reply, I agree that it should be metal and not rubber from the various photos that I've seen.
Now the hard part, trying to find one.
Jeff
Old Apr 1, 2019 | 01:11 PM
rocketraider's Avatar
Oldsdruid
64 is steel tube and is different between 2-barrel and 4-barrel engines. You need rubber grommet in the aircleaner snout, and a piece of rubber hose on PCV flapper end. That end also uses a spring-wing clamp to retain the tube to the hose.
My green 64 SF has an aftermarket A/C unit and has a piece of ugly-*** rubber hose in thePCV, as the aircleaner had to be rotated about 45 degrees to clear the compressor. I really want all that mess gone, but since one of the water pump/timing cover bolts is seized in the block, and natcherly that bolt holds the compressor support bracket on, that is not something I want to tackle right now
Old Apr 23, 2019 | 01:32 PM
Bee-Oh-Pee's Avatar
Captain Starfire
I guess I need to check the forum more oftener, as RocketRaider beat me to the punch by weeks. But yes, the tube on '64s is steel. Mine (Starfire, so 4V) was missing when I bought my car, but I was fortunate to find a pristine one from a '64 98 at the junk yard, then got the right part # PCV on eBay.
Not to hijack the thread, but while we're generally on the topic of air cleaners & Starfires, I've noticed that the repro AL air cleaner "top plate" that Fusick sells for '64 Starfires (actually, they say '61 - '64, and that might be the problem) is missing the "Use Premium Fuel" warning. Just a tid-bit of info for those of us looking for 100% authenticity -- even if perhaps not 100% originality.
Good luck....
Old Jun 1, 2019 | 03:17 PM
lunaboy's Avatar
The Rocket Astronomer
I have a metal tube just like yours., i also have the air cleaner available
OLDSter Ralph
Jan 16, 2018 12:27 PM
Erinyes
Mar 20, 2014 03:25 PM
Bee-Oh-Pee
Drivetrain/Differentials
Jul 12, 2011 12:52 PM
mcappi
Cars Wanted
Nov 24, 2009 03:51 AM
marinus_
Jan 28, 2008 04:45 PM
