Other Oldsmobiles Anything not listed above, such as F-85 (1961-1963), Firenza (1982-1988), Starfire (1961-66 and 1975-80), Omega, etc.
HELP with trim tag, and car info.
Old May 30, 2009 | 02:15 PM
doug garland's Avatar
I went over and checked it out more. It is a '64 Jetstar 1, and the trim tag info follows.
Oldsmobile Div General Motors Corp
09D Lansing Michigan
STYLE 64-3457 BODY BA 201
TRIM 307 PAINT FF
ACC C60
THIS CAR FINISHED WITH
MAGIC MIRROR ACRYLIC LACQUER
BODY BY FISHER
So, the car was built in Sept., 63, and possibly is one of , if not the first Jetstar 1's built. The VIN is 2182. The rear has an August date as well. Am I correct?
Old May 30, 2009 | 08:35 PM
rocketraider's Avatar
Oldsdruid
Yup- it's an early one. Doubt it's the first since by 09D (4th week September) production had been underway for several weeks and Jetstar I were built in all assembly plants. The 201 is tricky. I don't know if that means the 201st Jetstar I body made at Lansing body assembly or 201st Starfire/Jetstar I combined body. The Starfire had a couple of trim hole punching operations the J-I didn't have but was otherwise the same body.
It was originally Wedgewood Mist (FF, a light metallic blue) with white vinyl bucket seats (307) and is a factory air car (C60).
I haven't seen a 64 Olds of any stripe that didn't look good in that color.
Old May 31, 2009 | 06:41 AM
Thanks for the info . Don't think I'll part it out, or crush it now. Any idea how many JS 1's are left out there? I had found several on a junkyard website, bit I think they were Starfires instead. They had a different roof than my car. Thanks again.
Old Jun 1, 2009 | 05:08 AM
wmachine's Avatar
Trying to remember member
There is no way to know how many are still out there. Of almost any car, for that matter. Total production was about 16,000 so it was on the low side, and if there are many left out there, they're hiding! Very unusual to find one.
Old Jun 2, 2009 | 01:20 PM
Texascarnut's Avatar
Geezer
For what it is worth, the car in question was manufactured at the Baltimore Plant (code BA). The "201" would be a production sequence number for the Baltimore plant. Sequence numbers have nothing to do with the number of units of a given model type. They are just a number used to control the flow of parts to the assembly floor for that given car. The next car on the line could have had lower or higher number.
mstudley265
Jul 25, 2013 08:31 PM
gearheads78
Mar 6, 2012 06:20 AM
sx455raidercelticfan
Aug 1, 2010 08:03 PM
cherryrocket508
Jul 12, 2010 05:07 PM
compusign1967
Oct 30, 2007 08:19 AM
