Variable Displacement Compressor
Old Oct 31, 2023 | 09:36 AM
ART T's Avatar
Can you make a VDC work with an aftermarket system?
Old Oct 31, 2023 | 09:42 AM
If you want to modify the AC on your Oldsmobile to work with modern parts and refrigerant here are a few options.
https://www.oldairproducts.com/categ...4aagsqealw_wcb
https://www.originalair.com/
Old Nov 1, 2023 | 06:59 AM
oddball's Avatar
Just depends on how it is controlled. There were some in the 80's and 90's that actually used the suction pressure to regulate displacement - higher pressure = higher displacement, and leveling out the swash plate around 25ish psi, making it automatic. I'm idly digging through catalogs looking for one in a useful mount, but all of them have been pad mounts so far. Most of them use a solenoid, so you have to build a control system for the solenoid. Or figure out how to max it out and just lock it.
No aftermarket system that I've seen will directly control a compressor displacement solenoid.
Old Feb 9, 2024 | 07:11 AM
ART T's Avatar
Thanks for the replies. I am at a loss.
7314haywood
Apr 18, 2021 05:29 PM
Eastflorida
Jun 29, 2017 08:39 AM
chip-powell
Feb 1, 2016 03:39 PM
kartmaster
Sep 7, 2012 08:05 PM
lil_no
Jan 14, 2010 01:19 PM
