Trunk and door rubber bumpers install trick?
Old Jul 2, 2024 | 05:48 PM
OLE442's Avatar
I can't get the rubber trunk bumpers to get the little rubber nub cone through the hole to have them stay in place. I also will be installing the door rubber bumpers with the two cone shaped nubs on each one. Is there a special trick or tool to make it happen?
OLE442
Old Jul 2, 2024 | 06:39 PM
It’s much easier to pull them through the hole than push them, but access to the backside is probably limited.
Perhaps lube the nubs and push on the edges with a tool such as a small flat blade screwdriver?
Old Jul 2, 2024 | 07:07 PM
72455's Avatar
1972 U code Supreme
Old Jul 3, 2024 | 03:52 AM
69HO43's Avatar
When I did my 71, I put the bumpers on using a small diameter philips screwdriver with some soapy water on the nubs going in. I inserted the screwdriver into the holes and slowly and GENTLY pressed to stretch out the nubs where they popped into place. Don't go crazy, just a gentle, consistent pressure and they should pop in.
That was over 30 years ago, so there's that.
Go to 1:31 mark in the video below and they'll show you what I was talking about.
Old Jul 3, 2024 | 09:30 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
X4 on all the above.
Yes the WD along with the help of a tool.
Wood Popsicle stick or carefully work in into the hole with a screwdriver etc.
If there is a hole on the outside face you can push a blunt object the same or similar diameter as the hole and wiggle it into place.
Its not rocket science just lube and finesse.
Old Jul 4, 2024 | 03:10 PM
BillK's Avatar
I have found that a Silicon grease works a lot better than WD40 on rubber parts like that.
Old Jul 4, 2024 | 06:19 PM
bccan's Avatar
Glass cleaner/soapy liquid or silicone grease. Petroleum based lubes are potentially damaging to the rubber. Push/pull/twist simultaneously = best method, any single one will work, just not as easily.
holidaysedan
Body work
Dec 26, 2019 05:32 PM
scrappie
Oct 9, 2019 06:30 PM
MudEye
Oct 19, 2016 07:04 PM
JCMC64
Jul 31, 2014 05:59 AM
garth66
Aug 10, 2012 09:07 AM
