Tri Carb Linkage
The Feb 66 Service Guild bulletin covered Tri Carbs.
You can pick 30 deg. or 40 deg. for the secondaries to come in, depending on which hole you put the stud in (center carb). That is the only adjustment for that; just be sure when the center carb is fully open, so is the front carb. Then, bend the link from front to rear carb if needed so the front carb opens a little first before beginning to open the rear carb. you can see there is a slot in the pass side lever on the front carb base. The link should go through it so it slides from one end of the slot to the other as the front carb starts to open. the lionk goes to a hole on the corresponding lever on the rear carb. If done correctly, all 3 carbs are fully open at the same time.
