Tri Carb Linkage
Old Oct 15, 2010 | 09:15 AM
jim433149's Avatar
Tri Carb Linkage
Looking for instruction on installing linkage on my tri carb set up. Thanks for the help.
Old Oct 15, 2010 | 12:02 PM
Run to Rund's Avatar
The Feb 66 Service Guild bulletin covered Tri Carbs.
You can pick 30 deg. or 40 deg. for the secondaries to come in, depending on which hole you put the stud in (center carb). That is the only adjustment for that; just be sure when the center carb is fully open, so is the front carb. Then, bend the link from front to rear carb if needed so the front carb opens a little first before beginning to open the rear carb. you can see there is a slot in the pass side lever on the front carb base. The link should go through it so it slides from one end of the slot to the other as the front carb starts to open. the lionk goes to a hole on the corresponding lever on the rear carb. If done correctly, all 3 carbs are fully open at the same time.
Old Oct 15, 2010 | 02:14 PM
rroth01's Avatar
From: Orion Township Michigan 30 Miles North of the Murder City
Tri Power Carb Set Up
Give Sparky a call at Sparky's In Milwaukee..He is the guy...Well worth the call and the Money.
Old Oct 15, 2010 | 03:24 PM
Adjusting Tri Carb linkage is very easy, as I described. Come to the Tx zone show and I will show you.
Old Oct 18, 2010 | 01:05 PM
jim433149's Avatar
Thanks for your response on the opening setting. What I still need is how does the complete linkage go together.
bocoogto
Aug 13, 2020 05:30 PM
RandyS
Oct 4, 2012 12:36 PM
TripDeuces
Aug 19, 2010 02:36 AM
bocoogto
Mar 29, 2008 10:00 AM
bocoogto
Mar 27, 2008 05:49 PM
