Steering column
Steering column
I'm interested in swapping my fixed steering column for tilt. I've contacted Ididit and YearOne and was told by both '68 is the only year it can't be done. I have column shift, dashboard ignition. I can't use the column shift because my gear selector indicator is in my instrument panel and not sitting on top of the column. Plan "B" was to convert from column shift to floor shift but was told there was not a conversion kit for 2 speed ST-300 Jetaway transmission, only 3 speed and 4 speed transmission. Any suggestions? I'd appreciate the help.
You can get a factory 1968 tilt column with a column shift arm. Or you can get a factory tilt column for a floor shift automatic or manual transmission, they were factory options too. I've seen the aftermarket columns but am not familiar with them. If you get a factory one you can be sure it will fit and function.
John
John
John
John
From GM?
Thanks.
For the Cutlass/442 they also do not list any 68 columns.
http://garys-classics.net/restco.html
I found them as well, because of considering also a tilt column for my Omega.
The 1968-earlier columns do not lock and thus are smaller in diameter since they do not have a lock cylinder and mechanism. Ididit and other aftermarket companies primarily sell columns based on the 1969-up GM architecture. Even their columns that do not have a lock cylinder use the larger 69-up diameter to be compatible with all the aftermarket steering wheels. You can get an aftermarket column that will work in a 68, but you won't be able to use your original steering wheel due to the larger diameter. You could use a four spoke wheel with its larger hub, however.
I'll add that Ididit sells a tilt steering column for the 67-68 Chevelle and GTO. This is exactly the same column used in a 68 Cutlass. It uses the large diameter 69-up steering wheel hub.
Don't assume that any Chevy-centric vendor has a clue about what does or does not fit an Oldsmobile. How many vendors claim that their headers don't fit Supremes?
https://www.ididitinc.com/i-29487491...tegory:1310143
Your money, your call.
69 was the transition year to column ignition. That's the problem.
By the way, here's an aftermarket 67-68 A-body tilt column shift steering column from OPGI. I have no personal experience with this product. Again, it uses the 69-72 architecture so you need a larger steering wheel hub.
https://www.opgi.com/interior-access...t-pp00954.html
The 67-68 A-body columns all interchange. Ask them specifically what part of the dash does it not work with.
Sounds like Ididit wants to make a sale. I assure that column will fit your dash. The Ididit does not have the nut inserts that factory columns have.
Just so we're all clear, like headers, no aftermarket steering column will be a direct bolt-in. I guarantee that there will be differences in the turn signal connector, attachement of the mounting bracket under the dash, and possibly even in the spline diameter for the shaft. Be aware that some fabrication or swapping of parts will be required. That's called hotrodding. If you want a direct bolt-in, get a used original 67-68 column.
67442nut
April 4th, 2016 11:55 AM
Bitburger
December 30th, 2012 04:49 PM
69OLDSCUTCONV
May 19th, 2011 06:47 PM
