Sea foam
Your best bet is to run a top tier gasoline if you want a cleaner engine. Chevron, Shell, or 76 are all good gasolines.
http://toptiergas.com/deposit_control.html
Seafoam is just Alcohol, water, naptha
and refinery runoff pale oil. http://lyondell.com/lyondell/techlit...0_PALE_OIL.pdf
Also I suggest that you do some research on hydrolock before you use it. Even though it will be very hard to hydrolock anything with a small can of seafoam, it's a good thing to know about before putting random liquids into your motor.
Ok, I'm glad I asked. I've got a dieseling problem with my 1970 Ninety Eight 455 4 barrel. I bought it off a 90 year old woman and I'll bet she was using the cheapest gas available and probably lower octane that this engine requires. I believe It has 10.25:1 compression. I'll start with draining the tank and filling it with Super, give it a good run, and see what happens. Thanks.
Yes, I will check the timing. Thanks. It's on jack stands for now but when I let it down, I'm going to install the Pertonex coil/ignition in it also. Carb probably needs a rebuild after 38 years too. I'm going to stay away from Sea foam.
I like Sea Foam. I think it is one of the better oil/gas additives. They might not do much but they can give you peace of mind.
Oldsguy had a 1989 Ford LTD with a 5.0L engine that had sticky lifters and leaky valve guides. A friend of his had some auto tech students take a look at it. They drained the oil, filled it with Sea Foam and let it sit for a week. Then they drained the Sea Foam, added oil and an appropriate amount of Sea Foam to the crankcase and started it up. No more noisy lifters. However, the additive must have destroyed the valve guide seals because it smoked HORRIBLY!
Well, then I guess it's an option if Good gas and ignition/timing don't solve it. As I said, the previous owner was a 90 year old woman who used it to go to Bingo and the food store so It probably didn't see the highway much. It's got 76,000 original miles and it's a Texas car. The paint is fried but there's no rust. Still waiting for my QQ plates though (New Jersey!) and theres alot of snow and salt on the roads here. A good highway run might help. Thanks for all the input.
Does that carb have the anti-dieseling/stall dashpot or solenoid? I had the same problem when I shut mine down and just adjusted the solenoid/dashpot to specified rpm and the reset the timing to specs, always with premium gas and to running temperature. If it is doing it while driving timing and bad gas would be suspect as mentioned in the other posts. The Pertronix unit is a good move, first thing I do is put pointless conversions in my cars. I have had good luck with the Mallory Unilite conversion unit, have had one for 12 years in my Goat and has never missed a beat. I remember all the boat guys using that Sea-Foam stuff when I was a kid, my Dad swore by it. I always find tons of sludge in the engines of old folks cars, a lot just don't drive far enough to warm them up properly.
Allan
Allan
Where on the carb would that dashpot be located? I know theres a dashpot on there but I'm not sure if it's the one you are reffering to. Tom.
Look on the driver's side front of the carb. Sometimes they're electric, sometimes vacuum operated, and sometimes just a simple spring dashpot. The idea is to drop idle speed/throttle plate opening to where the engine starves for air and can't run.
You must remember 1970 was the peak of Olds high-compression. Those engines do not like low octane gas; they were designed for 100-106 octane. Use the best premium you can find and add some lead substitute to each tankful. Jack Podell www.jackpodellfuelinjections.com sells a good quality product that is about the only one I've found that does what it claims.
SeaFoam won't hurt a thing in your engine. Like Marvel Mystery Oil, a product doesn't stay around for 60+ years unless it does something right. Used properly it's a very good decarbonizer/top engine cleaner.
Trans fluid, MMO or Rislone are high detergent fine oils that, used in the crankcase, will dissolve sludge and free sticky rings and lifters. However, they don't do anything for carbon buildup on valves and pistons. You need a different type of solvent for that. Diesel and JP-4 are some powerful solvents if you're not afraid to put a quart or so in your tank when you fill up, but the car will smoke and stink like nothing you ever saw...
J, I'm not following your hydrolock theory. You put the SF in thru a vacuum port, it's going to vaporize before it hits the intake valves. A liquid goes from atmospheric pressure to 15-20" Hg vacuum, it's not going to stay liquid. That's why it's possible to pour some water down the carb throat and crack off carbon deposits. It vaporizes under engine vacuum, and when it hits combustion chamber temps, it flashes to steam.
Regards,
GoodOldsGuy
Oh you broke your leg?? rub some Robitussin on it, let it soak in. Haha. You never know.....
I have also heard that you can pour ATF down the carburetor while the engine is running to help clean the engine. I don't know if it works but it surely makes the engine smoke. I could definitely see how Sea Foam, Diesel, or JP4 would clean the engine when used in the same manner. I would just be afraid of damaging something.
Yes, thats my concern. I really don't know much about the history of this car axcept that an older person owned it.From that I'm just guessing that the cylinders have some carbon in them and thats whats causing the dieseling and read somewhere that Sea Foam clears that sort of thing. I know in the old Days my father used to take his cars on a (High Speed) highway run to "blow the carbon out" once in a while. Speeding tickets and insurance were cheaper back then though.
Well, I sea foamed it.(1970 Ninety Eight) Had it sipping through the PCV hose from a cup. Turned it off. Waited 5 minutes. Started it up and no thick cloud of smoke. It didn't diesel when I turned it off though. Should I have used another vaccum hose? Or did it do It's job? I was expecting a big cloud and I did it today because It's cold as hell outside and my nieghbors would not get that **** in their houses with windows closed. The gas gauge worked for a while too ( I recently drained the old gas with a siphon) maybe that loosened the mechanichels in the sending unit. Any thought? Tom.
From elsewhere, on the same site: http://toptiergas.com/retailers.html
TOP TIER Gasoline Retailers:
QuikTrip
Chevron
Conoco
Phillips
76
Shell
Entec Stations
MFA Oil Company
Kwik Trip/Kwik Star
The Somerset Refinery, Inc.
Chevron-Canada
Aloha Petroleum
Tri-Par Oil Company
Shell-Canada
Texaco
Petro-Canada
Sunoco-Canada
QuikTrip
Chevron
Conoco
Phillips
76
Shell
Entec Stations
MFA Oil Company
Kwik Trip/Kwik Star
Chevron-Canada
Aloha Petroleum
Tri-Par Oil Company
Shell-Canada
Texaco
Petro-Canada
Sunoco-Canada
All gasoline should be adequate. The U.S. Environmental Protection Agency requires a certain level of engine-cleaning additives in gasoline. And bulk gasoline before the additives go in must meet certain industry standards. But Shell and others trying to distinguish themselves from the discounters say that fuel meeting just those minimum standards won't keep your engine clean.
Norm
Or simply changed the oil and filter.
Only from a maintenance standpoint.
I understand it's a good "fuel stabilizer" for the off season.
Norm
I've used it a few times and it seems to work pretty well. Both engines ran better. It IS supposed to produce white smoke after you let it sit for a few minutes. Depending on the build up, you may smoke a lot, or a little. Both cars I used it on had carbs and I just slowly poured it down the throat (while revving the engine slightly)...then you dump a good amount down so that it stalls...let it sit for say 10-15 minutes and start it up.
#31
ive used sea foam quite a bit, but never really saw a difference either way with or without it, i just like using the stuff, makes me think im doing some preventitive maintinance or something, but i do know the stuff is getting expensive.
#32
jensenracing77
April 5th, 2010 01:48 PM
