rad support bushings
Old Oct 18, 2020 | 08:12 AM
sherlock1212's Avatar
Are the rad support bushing all the same on A body from 68 to 72 The ones between the rad support and frame
Old Oct 19, 2020 | 12:29 AM
Most vendors sell the Chevelle bushings. Cutlass is not the same. Fusick has correct core support bushings, as does Inline Tube.
Old Oct 19, 2020 | 05:07 AM
rob1960's Avatar
I replaced all my body bushings including the ones on the core support in '18, I really lucked out as everything unbolted with no problems!. I bought everything from Inline. Their core support bushings were a good 1/8" thinner than my originals so I had to add shims(like the assembly manual shows) to keep the sheet metal aligned properly. Lucky for me my local Napa store had the large body shims in stock in 1/16" & 1/8" thicknesses. My original core support bushing had no shims. You wouldn't think 1/8" would make much of a difference but before I added the shims on top of the new bushings the sheet metal was all out of wack at the front!! Big gaps at the front edge of the fenders!
Old Oct 19, 2020 | 01:42 PM
Thanks Joe for help
Old Oct 19, 2020 | 04:21 PM
briane's Avatar
Thorton also has the square bushings that I purchased recently. I have some also from Inline, I'll check their relative thicknesses and report back.
brandon reynolds
Mar 17, 2020 04:17 AM
tgilligan
Body work
May 27, 2017 06:06 PM
Oldssupreme
Aug 19, 2016 09:36 AM
deadeyejedi
Mar 16, 2015 03:38 PM
gasserdays
Nov 20, 2014 07:10 PM
