68 delta 88 fan switch cap screw size
does anyone know what size that little set screw on the cap on the fan switch is on a 68 delta 88? it is an allan screw right? I had one that said .05 but it seemed too big, and I guess that is a metric size, that is the smallest I have.
I have that dash I got from you, and I can see the screw better in that, but I just don't have a wrench small enough. I guess I'll have to try and find a precision set, I think the steering column is in the way to use the screwdriver type.
I misunderstood, I thought you needed a set screw. I've got another dash that's not as complete as that one. I'll dig through my allen wrenches to see if I can find the right size. Yes, the "L" shaped allen wrench might be easier to get in there with. John
Oldssupreme
February 20th, 2013 09:59 AM
