67 Toro Vaccuum Headlights - Help!
Old May 5, 2013 | 03:55 AM
tds's Avatar
tds
When I accelerate the vaccuum headlights lower themselves. When I let up off the gas they come back up . This does not happen when the car is sitting still - only when moving. Any help, suggestions, are greatly appreciated.
Tom
Old May 5, 2013 | 06:26 AM
How's the check valve on your vacuum reservoir?
Old May 5, 2013 | 08:11 AM
Vacuum leaks?
Old May 5, 2013 | 08:40 AM
Vacuum leaks?
Nope, probably not leaks - his reservoir check valve is allowing his reservoir vacuum to go down when his manifold vacuum does, hence a bad check valve.
A slow steady leak may be able to mimic a bad check valve, but it would also be enough to cause running problems, like a rough idle.
Old May 5, 2013 | 09:48 PM
2blu442's Avatar
Tom, you should be able to view a schematic from the Chassis Service Manual to locate the check valve Eric mentioned. If you don't have one you can go to wildaboutcars to view it online.
If you think you might be missing pieces I've got a 1967 Toro with a working headlight system. I could post some photos of the different componets if that would help.
John
Old May 5, 2013 | 10:40 PM
tds's Avatar
tds
John
Old May 5, 2013 | 10:42 PM
tds's Avatar
tds
John,
Thanks for the reply. Some photos would be great!
Tom
Tseverski@comcast.net
Old May 7, 2013 | 10:29 AM
tds's Avatar
tds
UPDATE - problem was improper vaccuum line routing. Routed all lines correctly, and now it works fine.
Thanks to everyone who responded.
Tom
rodan
Jun 18, 2014 07:41 PM
Big Blue 72
Mar 1, 2013 10:49 PM
rloxton
Mar 21, 2010 05:57 PM
millwrightrice
Jul 28, 2008 03:26 PM
drgnbumpr63
Nov 9, 2007 08:47 AM
