49 olds model 98 door handle trouble
Old September 9th, 2016, 07:54 AM
Salemhotrods's Avatar
Working on assembling a 49 old's 98 and the door open and close fine using inside handle but the outside handle rotates and hit the body before it disengaged the latch. They don't sag at all when not in use. Any help with be greatly appreciated.
Salemhotrods is offline
Old September 9th, 2016, 08:18 PM
Rocketowner's Avatar
Smile
You might try the parts from classic parts.com Door lock Spring and door latch repair clip. I know that replacing the spring would correct the "sagging door handle problems" on 49-50 Chev. And GMC trucks. They are very inexpensive. Another possibility is that the rod from the handle to the latch is not attached on one end. Larry
File Type: jpeg
Rocketowner is offline
Old September 9th, 2016, 10:05 PM
Thanks for the reply, I was actually able to take the latch mechanism out and was able to add some metal to the pin that actuates now it fully open and the handle stop about a half inch above the body .
Old September 10th, 2016, 06:20 AM
Glad you found the problem. Larry
davoaz
October 21st, 2015 01:28 PM
a1970442
January 30th, 2015 09:26 AM
Gitso
January 5th, 2015 05:14 AM
nj_cutlass72
March 4th, 2012 08:53 AM
croozer
August 15th, 2011 01:09 AM
Quick Reply: 49 olds model 98 door handle trouble
