Interior door handle not opening door
Old Oct 18, 2015 | 11:19 AM
davoaz's Avatar
Again, I know what the problem is as I fixed it before. It's the metal clip that holds the rod in in place between. As I take apart the door once again to get to it and reset it, is there a "trick to the trade" I can do to the clip to secure so it doesn't come loose again?
Old Oct 18, 2015 | 03:18 PM
CRUZN 66's Avatar
Olds Fever
If you haven't already, I would change the clip.... It could be worn, which is common if it is the plastic style.... If it's the steel spring style clip, then the clip and/or the rod end could be worn and then either one or both should be replaced....
Old Oct 20, 2015 | 05:26 PM
davoaz's Avatar
Thanks. I got a new steel clip in there. I haven't taken it apart to see if it popped out again. But I suspect that's what happened. You know where to get the rod?
Old Oct 21, 2015 | 01:28 PM
CRUZN 66's Avatar
Olds Fever
I doubt you will ever find a new one.... Possibly someone on this forum may have some spare door hardware, but you never mentioned what the vehicle is you are working on.....
MaxDog
Sep 30, 2012 09:37 PM
m1369d
Sep 9, 2012 05:45 PM
scrappie
Apr 9, 2008 05:12 PM
Skinny Puppy
Mar 31, 2007 05:00 AM
Skinny Puppy
Mar 15, 2007 01:14 AM
