Non-Oldsmobile Classified Please read forum guidelines before posting.
Old Buick 401 head gasket set '57-'63
Old May 26th, 2022, 04:15 AM
BSiegPaint's Avatar
THESE ARE SOLD - THANKS
Just in case someone here has an old Buick and could use these... I've had them for a while and put them on eBay a couple times, but no movement. It's an oddball item, but I still hate to throw these things away - and I know not everyone is on eBay. If anyone can use these, please let me know. If there aren't any bids on the eBay auction, I'll end it and you can have these for shipping cost.
https://www.ebay.com/itm/294992442327
BSiegPaint is offline
Old May 26th, 2022, 05:07 AM
Minibike Mark's Avatar
Dang, wish it was for a '66. Do you have any more Nailhead stuff?
Minibike Mark is offline
Old May 26th, 2022, 05:30 AM
BSiegPaint's Avatar
Sorry, I don't :/ These came in a group of parts I got long ago from a GM dealer that was moving. I'm about to the point where none of it is left.
Old May 26th, 2022, 05:43 AM
Ok, thanks.
Old May 26th, 2022, 02:42 PM
Tri-Carb's Avatar
I recall the 401 Buick was introduced in the 59 model year. 57 and 58 would have been a 364 nailhead. The gaskets may fit both engines.
Tri-Carb is offline
Old May 26th, 2022, 03:35 PM
BSiegPaint's Avatar
You are correct, and thank you. It may also fit the 400 and 425 up to 1966, it seems. I will add 364 to the eBay listing but great to have that info related here.
Old May 26th, 2022, 03:56 PM
Tri-Carb's Avatar
57-63 is correct for the application. The correction needed was 57-58 being for a 364.
Tri-Carb is offline
Old May 28th, 2022, 05:39 PM
Tri-Carb's Avatar
You may want to edit your ad to reflect that you are offering the thin head gaskets for high compression applications.
Tri-Carb is offline
Mr.Smooth
December 20th, 2021 10:13 AM
DENT
October 31st, 2012 02:08 PM
jag1886
August 15th, 2011 05:29 AM
1969cutlazz
May 16th, 2010 08:07 PM
1973olds98
October 24th, 2009 01:46 PM
Quick Reply: Old Buick 401 head gasket set '57-'63
