Non-Oldsmobile Classified Please read forum guidelines before posting.
Kenwood KRC-2001 2 shaft radio for sale
Old September 25th, 2020, 06:31 AM
seanm12's Avatar
I have an old 2 shaft car stereo for sale. $20 + shipping. It works, but:
1 - The back light for the display doesn't work. The frequency/clock are visible, but do not light up.
2 - The distance between each shaft is 5 3/4 inches. This is half an inch TOO CLOSE to fit my 67 Cutlass Supreme. Unfortunately they are not adjustable.
I picked this up at a swap meet a few years ago, got my car back together enough to want to work on the radio, and then made the discovery about the shaft distance.
seanm12 is offline
Old November 3rd, 2020, 05:35 PM
seanm12's Avatar
Bump
seanm12 is offline
Old November 3rd, 2020, 07:30 PM
72 Olds CS
RetroRanger's Avatar
I thought i replied to this before but Im thinking those shafts are adjustable in width if you take off the ***** and small nuts those plates will fit in to mutiple holes to adjust width. Just be careful moving them apart as some units used a string like set-up. do one side ata time move evenly and carefully.
RetroRanger is offline
Old November 3rd, 2020, 08:19 PM
MOTORHEAD
11971four4two's Avatar
IF you look at first picture
Above the **** shaft there is a gap
Very top of the chassis , it looks like a "plate" that allows for some adjustment.
Maybe loosen Big NUT at the base of volume **** shaft and slide apart / widen ?? there seems to be a wider gap there at the top
I did not see any incremental stuff like my super tuner had
You could possibly , also , modify the KENWOOD slightly and make fit real good Notch the case or the width shims , what ever you call them..
11971four4two is online now
Old November 6th, 2020, 02:04 PM
seanm12's Avatar
I tried to adjust things and took the top cover off. The circuit board the shafts go to are fixed. Thanks for the suggestions.
seanm12 is offline
Old November 21st, 2020, 02:48 AM
Vr1967's Avatar
I’m interested in it, if the radio is still available
sending pm
Vr1967 is offline
Old November 21st, 2020, 06:44 AM
seanm12's Avatar
VR1967 - I am posting a picture of the back with the wires in response to your question about RCA plugs. No RCA plugs but perhaps the 5 pin DIN plug may be helpful. It is still available.
seanm12 is offline
Old November 22nd, 2020, 06:47 PM
seanm12's Avatar
This radio has been sold.
seanm12 is offline
matt69olds
January 30th, 2022 09:49 PM
droptopron
June 29th, 2014 07:12 AM
bobb
July 7th, 2011 03:08 PM
dd1
August 31st, 2006 02:47 PM
Quick Reply: Kenwood KRC-2001 2 shaft radio for sale
