Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
Vortec Headed 355
Old Jun 10, 2022 | 04:23 AM
VORTECPRO's Avatar
Vortec Headed 355
My son was able to get to the track with his 355 Camaro recently, very similar type of build as Copper Cutlass's type of build but the Chevrolet version. His combination used a unported L31 Vortec head, 1.940/1.500 valves, .435/.460 lift hyd flat tappet cam, with a Diamond dished piston. Intake was a Vortec Super Victor with a 750 Holley. Track conditions were: 98 degrees, 120 grains of water, 29.20 barometer, 3200 feet DA, I was very happy with his first outing. Its worth pointing out the Vortec headed 350 can be be a stout low dollar power maker for sure. This fall when he can get into some very good conditions I will report back. 1/8 mile times. BTW running weight is a light weight 3200 pounds.
1.373 60 foot
6.81 660
97.5. MPH
Old Jun 10, 2022 | 04:50 AM
oldsmoboogie's Avatar
Cool, what transmission? Stock rear?
Old Jun 10, 2022 | 05:30 AM
VORTECPRO's Avatar
12 bolt 4.88 gear with a Metric 200 trans.
Old Jun 10, 2022 | 05:23 PM
Interesting choice in transmission, what does the converter flash at? What is the duration and lsa of that cam?
Old Jun 11, 2022 | 10:44 AM
VORTECPRO's Avatar
5200 Flash
258 @ .050
106
Old Sep 1, 2022 | 08:40 PM
68post's Avatar
Vortecs have a reputation of being able to handle some compression with only pump gas so why a dish with only 355 cubes ? I guess I should inquire what the actual compression is and perhaps I'll have my answer !? What fuel is he on ?
Definitely respectable times, what would be your/his next change on this engine - if any, or the car ?
Old Sep 2, 2022 | 10:45 AM
VORTECPRO's Avatar
This Camaro was built to run in IHRA G/CM class. G crate is: the GM performance 330 HP Vortec headed 350, it must use the factory type piston which has a dish. The cam must also be factory lift which is .435/.460 hyd flat tappet.
Old Sep 4, 2022 | 01:24 AM
68post's Avatar
Thanks for the info !
Old Oct 31, 2022 | 06:02 AM
VORTECPRO's Avatar
UPDATE
Had the Camaro out Sunday, went 10.79 @ 121.39 with a horrible 1.42 60, 7700 RPM through the lights, new tires next, looking for 10.60s, trans overhaul then 10.5s.
Old Oct 31, 2022 | 10:00 AM
harner's Avatar
1975 98 Regency Sedan
That's a lot of steam! As a 4th gen owner, I'm curious - what is the suspension setup?
Old Oct 31, 2022 | 08:55 PM
VORTECPRO's Avatar
I run a 12 bolt, moly heim lower bars, with a adjustable TQ arm, Santhuff shocks, best 60 foot 1.36
randomarrival
Oct 4, 2023 09:23 AM
olds 307 and 403
May 6, 2021 06:29 PM
ajr2820
Apr 20, 2021 06:41 PM
RocketV8
Jun 11, 2016 03:05 PM
380 Racer
Jun 4, 2013 04:09 AM
