Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
Possible LS swap on 1952 Deluxe 88
Old Jul 30, 2020 | 04:10 PM
John Black's Avatar
Hi guys,
I am having a really hard time finding parts for my olds having issues with fuel and spark. looking at options and it is really hard to find parts for that specific year. I have a ls1 that I was going to swap into a chevy truck but am leaning on slapping it into the Olds.
is there anyone that makes the mounts for the rocket 303 to LS or should I go Universal adjust till it fits I also have questions for the rear end and trans placement.
TIA for the help.
-John
the Olds
Old Jul 30, 2020 | 04:15 PM
redoldsman's Avatar
Proud Viet Nam Veteran
There is nothing manufactured for this swap. If you are going to that extreme you should probably consider putting a clip under the front end.
Old Jul 30, 2020 | 04:19 PM
John Black's Avatar
Okay, I am green to the Olds environment what would be my best options?
Old Jul 30, 2020 | 04:30 PM
redoldsman's Avatar
John, it kind of depends on what you want to do with the car. My 54 has a 324 which is just a 303 with a larger bore. Fusick Automotive has parts for your car. The 303 is a good simple engine. I would run a compression check to determine what shape it is in. Does it run now and how is the transmission. There are several of us on here that have been fooling with the old cars for some time. We are glad to offer suggestions and help. It looks like a nice solid car. What part of the country are you located in?
Old Jul 30, 2020 | 05:30 PM
John Black's Avatar
I am stationed in Hawaii so finding parts for the car is not exactl
Old Jul 30, 2020 | 07:06 PM
Your going to have to fabricate mounts among other things for an LS swap.
Old Jul 31, 2020 | 05:04 AM
John, I moved your post to the appropriate thread. Be aware that if you scroll too far you'll change to a "Related Thread."
BTW, that's a beautiful Olds. If it runs and drives then just go crusin'.
Old Jul 31, 2020 | 06:19 AM
59-59-59's Avatar
Yeah, that makes sense - swapping in a LS1 motor since you can’t find out basic fuel and spark problems
Old Jul 31, 2020 | 08:00 AM
redoldsman's Avatar
There is no reason to be a smart azz with a new member.
Old Jul 31, 2020 | 08:55 AM
70cutty's Avatar
Beer Connoisseur
Join http://ls1tech.com, a lot of info there. Plenty of swaps that you can read through.
Most likely you need to go with universal mounts.
That car would be bad a$$ with an LS1 under the hood. You would spend a fortune to get that 303 to run half as good as an LS1....... that you already have.
Old Aug 3, 2020 | 07:40 AM
Tedd Thompson's Avatar
If mine I would first find out what the problem is. You say spark and fuel,what issues with parts are you having? Most anything here in the states will ship to Hawaii it's a matter finding out what you need,that is unless you just want a hot rod. I know it seems a little intimidating at first with no history of finding stuff for a older classic car but with a little help most anything can be found for a 303, not that rare really...... Tedd
Greg N
Sep 13, 2014 10:27 AM
Railguy
Sep 27, 2010 08:23 PM
dwsshay
Sep 19, 2009 07:54 PM
oldsonharmont
Jan 10, 2009 08:49 AM
moparmusclecars
Sep 3, 2008 06:15 PM
