Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
Need bell housing adapter for ls swap..1970 olds 442
Old Sep 18, 2021 | 06:10 AM
COBRA2000's Avatar
Well my shop is ready to install my BRAND NEW LS engine. However, the bolt pattern on my turbo-400 transmission does not match the engine. The LS engine bolt pattern is designed for a chevy turbo-400 transmission..ugh!!! Come to find out olds,pontiac and buick have a different bolt pattern compared to the chevy turbo-400..So they are saying i need a BELL HOUSING ADAPTER for my transmission to make this work.They are having a hard time finding an adapter...So does anyone here know where i can find this adapter???
Old Sep 18, 2021 | 06:15 AM
Summit, Jegs, or most any other performance suppler.
JEGS 60170: Engine to Trans Adapter Plate Chevy Engine to B.O.P. Trans - JEGS High Performance
Old Sep 18, 2021 | 06:28 AM
COBRA2000's Avatar
Thank you!! That appears to be the correct one...
Old Sep 18, 2021 | 07:51 AM
COBRA2000's Avatar
You would think my shop could have found this??? But it was also closing time when they let me know about this...
Old Sep 18, 2021 | 05:13 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
I can't believe I am helping this swap but get something stronger like the Transdapt adapter. I had that flimsy one on my 8.5 to 1 307 headed Olds 350 connected to a 4L60E. I could only fit 4 of the 6 bolts on the cheap one like that. This one is notched and has the reduced head bolts.
https://www.summitracing.com/parts/trd-0060
Old Sep 18, 2021 | 07:09 PM
COBRA2000's Avatar
I was just looking at this one before i read your response...Thank you!!!
Old Sep 18, 2021 | 07:16 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
If you are going through all of that why not put in the matching 4L80E trans. See how easy I spend your money. Truthfully if the BOP 400 isnt fresh you will likely be replacing it shortly. Why not do it now. Plus you get overdrive.
Old Sep 18, 2021 | 07:46 PM
COBRA2000's Avatar
I was going to do that next year, but it is a thought???
Old Sep 18, 2021 | 11:52 PM
Hell yes. Do it now. You have committed this far. Do it right. You are shooting for a modern drivetrain car. Do it. Bank is obviously no issue. I would step up while you are there anyway. You will love it that much more.
JPinAZ
Feb 28, 2026 05:04 PM
Arno
Mar 18, 2017 06:31 PM
don71
Jun 8, 2013 10:27 PM
t_visker
Sep 12, 2006 07:47 AM
86killer
Apr 7, 2004 07:20 PM
