Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
My 388 stroker for my 1979 Cutlass
Old May 26th, 2012, 06:11 PM
ATrain1's Avatar
my388stroker.jpgI will post some pictures of the car when I get the chance. The engine is at the speed shop waiting for the dyno, I built it for about 550 HP. It will be going into my 79 with a turbo 350 B&M transmission with a 4.11 posi. The car is black with gold pearl and I am in the process of redoing the interior black as well. I just received my 3.5 inch cowl hood and also just put on a new set of American racing torque thrust M wheels. I am trying to have it ready for the KBPI car show on July 7th.
ATrain1 is offline
Old May 26th, 2012, 06:31 PM
ATrain1's Avatar
Updated pictures
CutlassatKBPI2011.jpgOld388stroker.jpgcowlhood.jpgCutlass.jpgFrom top to bottom are pictures of my Cutlass at the KBPI car show 2011, the old engine that I pulled and rebuilt, the new 3.5 inch cowl hood, and the new wheels.
ATrain1 is offline
Old May 26th, 2012, 07:26 PM
car guy
gearheads78's Avatar
Welcome to the site. I moved your thread to the non Olds powered area. Looks like it will move out pretty good. Keep us updated with the results.
gearheads78 is offline
Old May 26th, 2012, 08:28 PM
ATrain1's Avatar
I will thank you. I was going to post in the newbie thread but was not sure as I have been a member since I had my first Cutlass in 2010. I am on my second with my 79 and my first was a 88 that I was told was an LV2. Also I just wanted to add that my car was a SBC car from the factory with a 305 Chevy, I have had a lot of negative comments about the Chevy engine under the hood. I will admit that I am a big Chevy fan and I would have swapped it out anyway. I have gone the Rocket rout and I did not like the way it went. The way I look at it is they are all GM and all great engines. I am racing against my brothers built 403 Olds in a 78 T/A.
ATrain1 is offline
Old June 1st, 2012, 10:25 AM
ATrain1's Avatar
My 388 Stroker
I had my engine on the dyno yesterday and it mad 500 HP and 500 ft pounds of torque. On paper after it averaged out it was 491.4 HP and 500 ft pounds of torque.
ATrain1 is offline
Old June 1st, 2012, 02:17 PM
Welcome back Atrain!
oldcutlass is online now
Old June 1st, 2012, 03:04 PM
car guy
What rear axle do you have in that thing. If its a 7.5 you need to read this thread right now.
https://classicoldsmobile.com/forums...ded-video.html
Old June 1st, 2012, 04:11 PM
ATrain1's Avatar
Thank you.
I am running a GM 7.5 in it without drag slicks. I was joking with my friend as we watched the engine dyno that I was going to put a ring gear through the trunk, but I figured if it spun the tires off of the rim it would probably be okay. The rear end already has a few passes on it so now you really have me worried. Thank you for the warning I will have to figure what I am going to do now. I am getting a built transmission with a Trans brake and full manual reverse valve body so the weak link is going to be the rear end.
ATrain1 is offline
halfmoontrail
November 20th, 2015 08:11 AM
Wilson
November 22nd, 2011 04:52 AM
442 Jack
May 23rd, 2008 11:16 PM
palmers65
March 26th, 2008 07:44 AM
1972_442
November 25th, 2007 02:51 AM
Quick Reply: My 388 stroker for my 1979 Cutlass
