Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
LS Motor Conversion into A Body Cutlass
Old Dec 11, 2012 | 01:47 PM
  #41
jpc647's Avatar
Originally Posted by Aceshigh
My 1st: LS1/4L60e (26K) I bought was in 2006 from a 2004 GTO via Ebay for $4500.
Prices were a bit steeper back then for the LS1's.
My 2nd: LY6 I bought via Car-Part in 2011 for only $1850 plus the accessories for $300.
T56 I got from Texas separately.
Just for reference, how many miles were on the LY6 you bought off Car-Part? Did it come with the EMC, harness, etc?
Originally Posted by garys 68
If you cant find anything local, I bought both my LS motors off ebay auctions that expired without offers. I emailed lowball offers and both took them.
Shipping was under $100 to a local freight terminal. One even got to me overnight.
What do you consider low ball offers, can you be a little more specific on what you got, miles, rough price range(if you don't mind), etc.
Originally Posted by TRW
Mine was also an Ebay purchase and shipped directly to my door. Good luck in your search.
Most of the finds so far do not come with any of the wiring for the lights. how did you deal with this. are you lights still wired in as per factory?
The harness, in terms of needing to be modified, why can't it be plugged into the ECM(after it's been tuned for a different intake, etc) and standalone. What else does a factory 2500 harness tie into that has to be capped, or sectioned off? I'm guessing the fuel injection harness can be un routed from the main harness going into the firewall. What prevents those from being used as it, as standalone pieces. Then I could put different senders into the block for new gauges.
Old Dec 12, 2012 | 01:00 AM
  #42
Aceshigh's Avatar
Mine came with 58,000 miles or 61,000 miles.....I forget.
The $1850 was just the motor.
The extra $300 was for the E38 ECM, the harness, the alternator, water pump, power steering bracket & pump, exhaust, etc.
Old Dec 12, 2012 | 01:30 AM
  #43
garys 68's Avatar
My 05 5.3 L59, under 50K miles was $800 + shipping for complete takeout, acessories, harness, ecu, pedal, TAC, MAF, sensors, even fuel pump. Dont recall the asking price. Looks like "buy it now" price on low milage 5.3 takeouts is $1200-1500 on ebay now.
Get EVERYTHING you can with the motor. Extras will cost A LOT if bought seperately.
02 6.0 LQ9, under 50K miles was $1600 + shipping for a complete takeout (although that was about 7 years ago). I remember the buy it now was $2400. I really wanted the high compression LQ9 for the 68 corvette, so paid a bit extra vs the LQ4. Besides, the LQ9s were mostly in Escalades, no one ever pulled a horse trailer or plowed snow with an Escalade.
Used to be they couldn't give away the LY6s due to VVT and programming. But now that people have figure how to remove or keep and reprogram, they're really at a premium.
And everything you need to know about harness mods and making your standalone.
http://www.lt1swap.com/
Old Dec 12, 2012 | 04:29 AM
  #44
TRW's Avatar
TRW
My LY6 was shipped to my door for $2130. It had 63k miles on it and included pretty much everything-harness, ECM, starter, MAF, all belt driven accessories, gas pedal (and plug), Fuel module, battery cables and the large junction box with the fuse.
As far as the lights for your car, it's probably best to do some reading on what is required to rewire one of these LS motors for stand alone operation. The best way to explain it is that it is a marriage of the motor's electrical system and your car's electrical system. Most of your car's electrical will stay as it is, with the exception of the coil, charging, starter and gauges/dummy lights. The new engine harness will need a fuse/relay box added under the hood to supply the system with power. You will end up with a "stand alone" system that only requires about 4 wires to run it (+12V constant, +12V switched, ground, and a starter wire).
Tom
Old Dec 21, 2012 | 07:52 AM
  #45
71403's Avatar
That's worth a repeat.
LS swaps can bring nickel and dime to a whole new level. Yards vary in their definition of "cutout" - mine thought no accessory bolts, no engine cover, and cut O2's were part of the package.
Schober Motorsports
Jun 26, 2021 09:35 AM
Vistabrat72
Apr 2, 2012 06:38 PM
OldsMotion
Jan 10, 2011 02:56 PM
mrstevek79
Brakes/Hydraulic Systems
May 10, 2008 10:02 AM
bingo
Apr 13, 2007 06:52 AM
