Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
Jahns Pistons how to ID ?
Old Apr 12, 2023 | 09:16 AM
omy442's Avatar
Sorting the 66-67 Olds parts collection continues.
Included in the 66-67 Olds parts collection, were a set of new Jahns Pistons.
Unfortunately the box label was missing part number. I'm guessing it's from the 70's based on age of box and shipping label typewriter font.
Did some research and back in the day Jahns was a no frills budget piston.
Didn't see any part number inside the piston only the name.
I can have a machine shop micrometer size, but not sure if that will help identifying what they are.
I found them next to a set of standard Oldsmobiling 350 Pistons and rings.
Mader
jm68442@yahoo.com
Old Apr 12, 2023 | 09:29 AM
The piston diameter and pin height (compression height) will really help. Also the dish volume, if they are dished - can't tell from the pictures as the pistons are wrapped.
Old Apr 12, 2023 | 09:54 AM
66-3X2 442's Avatar
Mader
jm68442@yahoo.com
350 pistons are commonly used in 65-67 400 engines.
Old Apr 12, 2023 | 10:18 AM
BillK's Avatar
Actually Jahns was one of the early race piston manufacturers and as far as I now they were very good for their time, certainly "not no frills budget"
If your machine shop can measure the piston diameter and the pin height that is all you need to properly identify them. They almost look to me like they have a small dome on them. Hard to tell for sure by the picture. Are you certain there are no numbers on the pistons anywhere ?
What is on the label where you have it blacked out ??
Old Apr 12, 2023 | 11:23 AM
omy442's Avatar
I blacked out the ship to address.
I'll have to dig out the piston tote.
The wrappings disintegrated on the one I looked at, put it back in box then snapped a pic.
Pins are pressed in, but Pistons have been sitting for a long time.
Mader
Old Apr 12, 2023 | 11:43 AM
66-3X2 442's Avatar
Mader
I bet the pins are just stuck,pins press into the rod,not the pistons.
Old Apr 12, 2023 | 11:54 AM
BillK's Avatar
Exactly. What I have found is running under real hot water will expand the piston enough to get the pins to move. Once you get them free a little CRC or WD40 will free them up.
Old Apr 12, 2023 | 12:40 PM
omy442's Avatar
I'll just have to make time to visit my machine shop and get Pistons measured.
I'm curious to know what they are.....
Mader
Old Apr 19, 2023 | 07:45 PM
Tedd Thompson's Avatar
Can't the box with UPC number be run, and the information found, I know on hardware each product has its own UPC number...Tedd
Old Apr 20, 2023 | 03:47 AM
BillK's Avatar
Pretty sure the Jahns pistons are from a time before bar codes existed, or right about when they first came out
Old Apr 21, 2023 | 05:16 AM
omy442's Avatar
Box appears to be from early 70s with manual typewriter shipping label... before barcodes and upc's.
I'll take to machine shop to get measurements.
Mader
Old Jun 15, 2023 | 12:19 PM
omy442's Avatar
6.15 update
While loading totes into trailer for homecoming, I looked again at box and other end had part number.
I called JE Automotive but their records didn't go that far back.
It's part number 8-1156 H RP
.60 over with 13:1 compression ratio with 1/8 dome.
I'll search later.
Mader
Old Jun 15, 2023 | 01:45 PM
v8al's Avatar
Registered Olds Owner
I found this on the internet supposedly from a 1969 Jahns catalog. Maybe someone has an old catalog and confirm.
1965-67 400 &425 Bore sizes 4", 4.057, 4 1/8 flat top is #1156
Old Jun 15, 2023 | 07:54 PM
omy442's Avatar
Thanks for the info !
Old Jun 15, 2023 | 09:34 PM
redoldsman's Avatar
Proud Viet Nam Veteran
I can remember Jahns being the piston most hot rodders used back in the 60's. They were known as premium stuff.
ben442
Dec 3, 2022 03:11 PM
billrob71
Jun 23, 2022 06:32 AM
2blu442
Jul 1, 2021 11:12 PM
scott442
Jan 23, 2019 06:28 AM
STLCRZY
May 25, 2016 02:14 PM
