Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
Help please
Old August 11th, 2014, 04:38 PM
Csmith331's Avatar
Help please
Looking to drop a chevy 350 in a 40 series 60. Question is what are my options in transmissions to go with it and what other items would be needed to do the swap? Not much experience in this area. Thank you for you time and suggestions. Mainly looking for something that would be easier to find parts for when something messes up with the motor.
Csmith331 is offline
Old August 11th, 2014, 04:54 PM
61reoldsman's Avatar
huh? whats a Chevy ?
61reoldsman is offline
Old August 11th, 2014, 05:50 PM
I moved your thread to the non-olds powered section. This is going to be a major mod as you will have to fabricate mounts. You can go with any trans you want, I think for simplicity's sake a T350 or a T400 would be the easiest. Other things to consider are steering column or a floor shifter, rear differential swap and cooling for both trans and the engine. It will require some wiring upgrades as well. Make sure your brakes and steering components are up to snuff.
Just a note, you can also run small bock Olds and BOP trans since your having to fab mounts anyway.
oldcutlass is offline
Old August 11th, 2014, 05:51 PM
I'm not going to bust on someone in the Non-Olds-Powered forum, but are you thinking of the C-word because you've already got one gathering dust in the garage, or for some other reason?
If you're starting from scratch, why not go Olds?
You can build a nice 455 with plenty of power for a 1940 and not break the bank.
... And when people at car shows ask, you can open the hood and show them an Olds motor.
MDchanic is offline
aquabird
October 2nd, 2013 10:34 PM
drtdobber
February 14th, 2007 01:16 PM
Yllwbnna
Cars Wanted
November 13th, 2006 09:50 AM
70ra455
May 26th, 2006 12:30 AM
melsolds69
May 24th, 2006 05:58 AM
Quick Reply: Help please
