Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
Gen 1 Rx7 SBC swap.
Old Apr 29, 2022 | 04:35 PM
CANADIANOLDS's Avatar
Gen 1 Rx7 SBC swap.
This is my youngest sons first car. He’s 21 ,, I’ve been helping over the last year to get this swap up and running.
its a real solid one owner car that he sold the complete drive train out of it and has been picking up used parts to get it together. It’s a real low dollar build . Doesn’t have much money into it but a ton of hours..it’s been just over a year now …started it up today.
it’s a $150.00 350 chev from an early 70’s cop car. We didn’t realize until we stripped it down that it had later 305 small valve heads on it..so we kept them and installed the “big” 1.84” 4 barrel valves to keep the compression up using steel shims.
mild pocket port to fit the valves
218/218 @ .050 .480” with 1.6 used stamped steel rockers.
the block got a hone and some new rings. Intake is an antique Edelbrock single plane streetmaster. Crank got a polish and new bearings..stock rods and cast pistons are original…their loose 😎
edlebrock 750 AVS 😎, pertronix dizzy and coil with limiter and MSD wires. Trans is a 5 speed world class form a mid 80’s mustang, rear is an 8.8” ford from a ranger with 4:10’s that we narrowed.
CVR electric pump, aluminum rad, electric fan , HV Holley mechanical pump.
Old Apr 30, 2022 | 06:28 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Edelbrock Street Master, it has been 30 years since I saw one. It was put on a stock rebuilt 71 sbc 350 from a big car with a 750 Holley, put in a 77 Chebby 1/2 ton, not a good combo. That is the bonus of the LS craze, anyone who wants a sbc can get them nearly free. More pics please.
Old Aug 23, 2022 | 01:45 PM
Rear end is in and driveshaft made. 8.8 Ford we narrowed here. Welded on all the old stock Mazda mounts with energy suspension poly bushings and a perfect launch girdle. 4:10’s is too much for the motor,, but that’s what it’s fit for now
change out later
Old Aug 23, 2022 | 02:16 PM
Looks like a fun project.
Old Aug 23, 2022 | 04:28 PM
75 W-30 H/O's Avatar
I'm normally not interested in off brand builds but this is fun. Keep the updates coming.
Old Aug 23, 2022 | 05:38 PM
all wrapped up. Going in for exhaust soon. no room for full length duals so we are thinking 3.5” single with one 3.5” high flow muffler. See what they can figure out.
stainless block huggers . Only one pipe had to be rerouted around steering box
Old Aug 23, 2022 | 05:46 PM
Stock Mazda rear 4 link bars. Shortened the uppers and lengthened the lowers to get corrected pinion angle. Hope they hold up 😁
Old Aug 23, 2022 | 05:50 PM
This is how it sits.. I think we’ll lower the rear once he gets the rear tires and rims . These are temporary
Old Oct 10, 2022 | 05:02 AM
Old Oct 14, 2022 | 03:03 PM
Old Oct 15, 2022 | 07:12 PM
How small is that crossover to clear the drive shaft? The down pipes look nice.
Old Oct 15, 2022 | 10:10 PM
2 1/2” all the way both sides to 3 1/2” single.. the shadow makes it look weird.
This is the crossover
Old Oct 16, 2022 | 07:43 AM
Yeah, 2.5" isn't bad, not going to choke it. Plenty of gear and power. What does this car weigh?
Old Oct 16, 2022 | 04:23 PM
Old Oct 16, 2022 | 04:25 PM
Old Oct 16, 2022 | 04:27 PM
Old Oct 16, 2022 | 04:33 PM
Old Oct 16, 2022 | 04:35 PM
Don’t know, we’re gonna weigh it
Old Oct 22, 2022 | 12:49 PM
Some other pics..he’s been driving it for a few days now. Gotta get some sticky tires,,it breaks the tires loose way to easy😎
front end needs to come up an inch or two…before the pan and down pipes get ripped off
Old Aug 17, 2023 | 04:44 PM
Took it to the track with the Olds club. His first time ever down the track in any car..13.1@107 with a spinning 2.3 60’
should be min 12.5 with a decent 60’
Old Aug 17, 2023 | 05:00 PM
Sure looks like fun to me.
Old Aug 18, 2023 | 08:57 AM
Oldsguy's Avatar
Past Administrator
Depending on the exhaust sound, can you spell S.L.E.E.P.E.R. ? That car looks stock to me.
Old Sep 25, 2023 | 05:54 PM
we tried to keep it stock looking. had to cut out the hood bracing and use a big drop air filter base so we didn’t have to cut a hole in the hood.
we have some negative offset rear rims for it now so it can be lowered down to clear the wheel well lip.
single exhaust out the back… shifter and interior looks dead stock . It’s a blast to drive
Old Sep 30, 2023 | 08:28 AM
Tedd Thompson's Avatar
You went to the wrong track, if the wight balance (50/50 is not too different from the Wankel vs the SBC it belongs on a road racing track. RX7s are great road racers and Cobra killers when HP is added and suspension isn't changed much. Very light car and a ton of fun.... Tedd
Old Sep 30, 2023 | 09:02 AM
skyhigh's Avatar
1972 Cutlass Town Sedan
Yes that will shock lots of people that try to run it lol, very cool build.
Old Sep 30, 2023 | 09:51 PM
I'm really impressed with the build quality. It sure don't look very low-buck.
Old Oct 22, 2023 | 08:25 AM
biggest expense so far has been the custom stainless exhaust. that wasn’t cheap. It does have a used muffler and the shorty headers were only $114.00 Canadian form eBay.
he sold the complete excellent running original engine tranny and rear end to fund most of the project
Old Mar 25, 2025 | 07:36 AM
Got some serious meat on it now with Moroso long studs ..Mickey Thompson SS streets on some mid 90’s Jeep Cherokee 4x4 rims .. perfect negative offset
Old Jun 2, 2025 | 05:05 PM
12.46@110
74sprint
Nov 27, 2019 09:30 PM
Supremely72
Aug 6, 2019 10:06 AM
CJG
Jul 17, 2016 03:52 PM
dyeager535
Aug 28, 2014 09:27 PM
Thekid1992
Jul 26, 2014 02:01 AM
