Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
buick 455 in a delta 88
Old Jun 8, 2011 | 02:58 PM
70 holiday coupe's Avatar
i was wondering if i could fit a 71 buick 455 in a 70 olds delta 88. and how hard would it be. im only doing it cuz i can get the buick motor and trans for free and it runs good. and i want to get the car on the road and drive it til i can save up enough money to biuld my olds motor.
Old Jun 9, 2011 | 06:53 AM
copper128's Avatar
Lt. Buzzkill (ret.)
Sure, it'll fit. You'll need frame pads (maybe: Olds didn't use frame pads on 65-70 big cars - not sure about Buick) and motor mounts from a 67-70 full size Buick. It'll require mods to the engine wire harness (Buick distributor is in front, starter on passenger side) and the exhaust system. Might need to change driveshaft length - that depends on whether the trans tail length and rearend pinion length are the same between both cars.
ralsy
Jun 30, 2012 04:22 PM
Jayycobb
Drivetrain/Differentials
Dec 6, 2011 07:27 AM
70 holiday coupe
Jun 3, 2011 03:10 PM
regalrocket
Apr 20, 2007 01:27 PM
mikkim129
May 10, 2006 07:06 PM
