Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
68 442 starter to ignition wiring
Old February 12th, 2014, 09:47 AM
BilgertGrape's Avatar
there's a slew of problems with this car but I'm trying to wire the starter to the ignition and accessories. I need help!!!! Also none of the gauges work. Any help is appreciated!!!
BilgertGrape is offline
Old February 12th, 2014, 09:55 AM
Do you have a wiring diagram for your car?
Since the starter is on the passenger side, I used a ford starter solenoid for my mini starter. I extended the battery cable to the firewall behind the passenger side valve cover where I mounted it. From there I wired in a relay to work off the resistance wire for the ignition and supplied an hei with full battery voltage through a 12ga wire. The rest of the stock wiring is intact to the gauges.
oldcutlass is online now
Old February 12th, 2014, 10:00 AM
no unfortunately I don't
Old February 12th, 2014, 10:02 AM
This is for a Chevelle, very close. As you have a 454 in your car I moved your thread to the non Olds powered section.
http://documents.clubexpress.com/doc...39Whov6el8E%3d
Old February 12th, 2014, 10:06 AM
I'll take a look at it later. Thank you very much though!
Old February 12th, 2014, 10:09 AM
It's also nice to get some younger blood into the hobby. If you have any other questions feel free, been there and done that. The 68 schematic starts on the 3rd page.
Old February 12th, 2014, 10:24 AM
I'm sure I will be back very soon! Haha I'd love to see this car running!
Old February 12th, 2014, 10:35 AM
Your almost there, the wiring is not that hard. The purple wire is goes to the starter solenoid if you don't want to use a Ford solenoid, get a longer cable for the hot wire to the starter from the battery and route along the fender to the firewall and down from behind the passenger valve cover. I don't know what your using for a distributor.
Old February 12th, 2014, 12:07 PM
Unfortunately there are no purple wires...whoever had the car before us made sure to make everything as hard as possible by using one color of wire FOR EVERYTHING!!! There is a pushbutton to start the car as well as a turnkey...and that pushbutton looks the same as the one right next to it that is connected to the general lee horn (kind of cool but the amount of wires added is such a headache)
Old February 12th, 2014, 12:55 PM
Then the wire from the push to start needs to go to the starter and then you need to find a wire that's hot when the key is on to the coil+ (ignition).
66cutlass
May 30th, 2013 07:19 AM
66cutlass
May 12th, 2013 01:28 PM
dennisspeaks
September 24th, 2011 01:10 PM
mv213
May 31st, 2010 04:01 PM
64oldsd88
March 30th, 2009 12:16 AM
Quick Reply: 68 442 starter to ignition wiring
