Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
6.0 LQ9/4l80e swap using Holley parts
Old Sep 9, 2020 | 08:42 PM
  #41
70cutty's Avatar
Beer Connoisseur
Well done, enjoyed reading your thread. You made it look too easy.
Thank you Eric. I was trying to keep the thread simple and informative, instead of going into every single little detail.
Holley has really done their homework on swap parts, everything bolted up and driveline angles were perfect.
Old Dec 15, 2020 | 10:37 AM
  #42
70cutty's Avatar
Beer Connoisseur
Took the car to work today and hit 2500 miles with new engine/trans. Car runs perfect, no hiccups. Get in, start and drive off. Had the tuner go over the data, he made some small adjustments to the fuel table just to dial it in.
I've been messing with the tuning just to get familiar, it's user friendly. I adjusted my shift points to my liking and also set the lockup on torque converter at 65mph.
On the freeway, it runs smooth 80mph at 2500rpm, finally I can keep up with traffic. From 80 to 120 feels almost instant, as soon as trans grabs 3rd it's gone.
Circle D torque converter is a beast, drives like stock putting around town, but when I step on it the monster comes out.
DBW setup is great, there is no delay and IMO feels better than cable TB.
Overall I'm very happy with the swap.
I was planning on boost, but might just keep it NA, it's fast enough.
Old Jan 21, 2021 | 10:24 AM
  #43
mike1976's Avatar
Very nice build! I used a lot of the Holley stuff with my LS swap and they look good and work great. I used the original truck brackets with mine and got a smaller pulley for the power steering. How did you find the hood clearance with that intake? I am still having issues with hood clearance but I went for the old school look with the throttle injection.
Old Jan 27, 2021 | 05:39 AM
  #44
70cutty's Avatar
Beer Connoisseur
Thank you, It's close but it clears just fine. Probably about 1" between the top of the intake and hood, and 1/4" gap when cover is on the intake.
Old Jan 28, 2021 | 04:23 PM
  #45
Loaded68W34's Avatar
Very clean, are you planning on putting wipers back on? A 96-02 camaro wiper motor will give you a delay system with hidden wipers, but it requires some modification.
Old Jan 30, 2021 | 06:30 AM
  #46
70cutty's Avatar
Beer Connoisseur
Thank you. I haven't figured out the wipers yet, but Camaro definitely looks like an option. I'm gonna pick one up from pick-n-pull and see what it would take to install.
Old Jan 30, 2021 | 06:37 AM
  #47
VORTECPRO's Avatar
Originally Posted by 70cutty
For the converter I went with Circle D 245mm billet converter with 3200-3400 stall. OEM flex plate and spacer, ARP bolts were used to bolt flexplate to the engine.
Crossmember is Holley/Hooker part #71222007HKR
Everything fit like a glove, no room to spare but it fits.
Approximately how heavy is that converter?
Old Jan 30, 2021 | 06:59 AM
  #48
70cutty's Avatar
Beer Connoisseur
If I remember correctly right around 32lbs dry.
Old Jan 31, 2021 | 05:14 PM
  #49
RustyNCA's Avatar
Started working on my wiring yesterday. So if you run the MAP on the intake, you ignore that blue MAP line back of the ECU? Also on the MAP, since you and I both are going TB SS. Is that the adapter that goes from the LS Gen 3 map to a Gen 4 LS3 connector. I noticed mine wouldn't plug in.
And the hot lead you have going to the Alternator, where did you get that? It looks very nice.
Bryan
ECU has an onboard MAP, and vacuum line can be run from the back of it to the intake. I choose to use the MAP on top of my intake, for which I needed an adapter cause it was newer style.
Old Feb 1, 2021 | 01:19 PM
  #50
70cutty's Avatar
Beer Connoisseur
For the MAP - If you use MAP on intake, ignore the blue line coming from the Terminator. The adapter wire for MAP is Holley part # 558-416.
The alternator wire I crimped the ends my self and wrapped it in the sleeves that I bought on Amazon.
Old Feb 1, 2021 | 02:02 PM
  #51
RustyNCA's Avatar
Thank You, I'm slowly plugging through this. Looks like I'll be waiting on the headers till probably May Trans Mount now shows middle of Feb.
Old Feb 1, 2021 | 04:55 PM
  #52
70cutty's Avatar
Beer Connoisseur
Anytime man, glad I can help.
Looking good.
Old Feb 26, 2021 | 06:00 PM
  #53
DewChugr's Avatar
Photoshop God
Almost exactly what I’m doing except we’re going to fab a trans crossmember and I’m going to use megasquirt. I combined an LY6 short block with a LH6 top end. Good to hear everything went in well.
what gears and what kind of mileage do you get?
Old Feb 27, 2021 | 07:08 PM
  #54
70cutty's Avatar
Beer Connoisseur
I'm running 3.42 gears. I have a heavy foot, I love to open it up and let it rev, so far I've been getting 17-18mpg on average.
On my road trip San Francisco to LA couple of weeks ago, I averaged 23mpg, 1k miles in 3 days, mostly highway. Like I said I have hard time keeping my foot of the gas pedal.
Old Feb 27, 2021 | 10:11 PM
  #55
RustyNCA's Avatar
Looking good.
Things have gone an entirely different direction now....
Old Feb 28, 2021 | 06:34 AM
  #56
70cutty's Avatar
Beer Connoisseur
My favorite kind of intake. Looks great man.
I'm working on putting mine together.
Old Feb 28, 2021 | 10:43 AM
  #57
It looks like you are using the LSA to LS1 cathedral port head adapters. What computer are you running?
Old Feb 28, 2021 | 11:47 AM
  #58
RustyNCA's Avatar
Yes. Using the Holley X Max system.
Old Feb 28, 2021 | 02:34 PM
  #59
70W-32's Avatar
Youve done a great job, any idea what you have $$$ wise into the entire swap?
Any autopsy results on the 463 yet?
Old Mar 1, 2021 | 06:18 AM
  #60
70cutty's Avatar
Beer Connoisseur
Thank you. I think around $10k-ish, that's including rebuilding the engine.
I finally got the 463 on the engine stand, about to dig into it soon, other projects keep getting in the way.
Old Mar 2, 2021 | 12:02 PM
  #61
DewChugr's Avatar
Photoshop God
Interested, do you have links or info on this mod?
Old Mar 2, 2021 | 12:59 PM
  #62
I used the plate and wiper arm from a 98 camaro:
I cut and welded the plate into my firewall and welded the cutlass pin to the 98 wiper arm. This took some trial and error to get the operation right.
I used the schematic for a 98 wiper switch along with a 3 pole 8 position rotary switch and a variety of resistors to make my own switch with 7 speeds and park (8 positions)
The three ***** on my dash next to the column are the headlights (far left) which I almost never use because I have a dakota digital acc delay module which turns the lights on at night, power mirror (far right) although the mirrors look like 71-72 sport mirrors, they are actually 81-82 corvette electric power mirrors, and the wiper **** in the middle.
Old Mar 2, 2021 | 01:09 PM
  #63
DewChugr's Avatar
Photoshop God
That's awesome. Thanks!
Old Mar 4, 2021 | 05:49 AM
  #64
70cutty's Avatar
Beer Connoisseur
I used the plate and wiper arm from a 98 camaro.
Great info, thank you. I will try to do the same.
Old Mar 6, 2021 | 04:24 AM
  #65
Very, very nice job. I love it!
Old Aug 3, 2021 | 01:06 PM
  #66
Phoenix8990's Avatar
I know this is a somewhat old thread, but, WOW, amazing job!
Steve
Old Aug 3, 2021 | 02:12 PM
  #67
70cutty's Avatar
Beer Connoisseur
Steve
Thank you Steve!!
Old Aug 21, 2021 | 06:50 PM
  #68
pettrix's Avatar
Great write up!
I also get frustrated with the 455's and their lack of parts availability, reliability, expensive $$ rebuilds, strength, etc.
LS swaps into A Bodies is very tempting. Especially if you want a Pro Touring car like yours that you can drive and take anywhere without worry. The overdrive trans and EFI makes it a bullet proof reliable setup. Doing 80mph on the highway with a locked converter is pretty cool in a 50 year old car.
Will all LS1-3 engine oil pan clear an A -Body front crossmember?
Old Aug 21, 2021 | 07:45 PM
  #69
RustyNCA's Avatar
Originally Posted by pettrix
Great write up!
I had a great experience using the Holley LS swap parts. It's a very close fit using Holley's pan. So I would say no to running the stock pan.
Old Aug 21, 2021 | 08:52 PM
  #70
pettrix's Avatar
This LS2 might be going into an Olds 442. Already have a 2004R (Stage 3) with a Universal bolt pattern so it will bolt right up to the LS engine. The flexplate will probably have to be changed or machined but otherwise it should be a direct drop.
Old Aug 22, 2021 | 06:45 PM
  #71
Kind of like asking if a BBC pan will fit a Chevelle. It all depends on what pan/ application you are talking about. I used a stock F-body LS1 pan (out of a 98 camaro) with UMI LS mounts in my Vista. Truck pans will not work and I don't think the GTO pan will either, but I am not sure. The Hummer H2 pan will supposedly fit but they have a deep sump that may bottom out on the road if the car is lowered. If you are using an LS pullout from a F-body, use the stock pan, otherwise, the holley pan is a good choice like mentioned above.
Old Aug 23, 2021 | 08:55 PM
  #72
pettrix's Avatar
The LS2 has a Corvette C6 oil pan on it. Isn't that a low profile pan like the F Body pan?
Dimensional, compared to a 4L80e, is a 2004R the same size or a shorter trans?
Old Aug 24, 2021 | 09:24 AM
  #73
70cutty's Avatar
Beer Connoisseur
I'm not 100% sure but I think you'll run into tie rod clearance issues with C6 oil pan.
200r4 is shorter than 4l80e.
For problem free installation I would use Holley 302-2 or -3 pan, and Holley stock position mounts. They locate the engine in the exact spot where olds engine would be, so you don't have to do move the transmission from its location.
Old Aug 24, 2021 | 09:29 AM
  #74
70cutty's Avatar
Beer Connoisseur
For 2004r to work with LS, you will have to figure out the TV cable. Since your LS2 has DBW throttle body there is nothing to hook TV cable to. You either have to go DBC, or figure out modifications to the DBW pedal in order to hook up the cable to the pedal and keep correct geometry. It's not easy but I know it can be done, I've seen couple of build on Ls1tech that done it.
To bolt it together I would use TCI 4l80e flexplate that has multiple bolt patterns, no need to machine anything.
Old Aug 24, 2021 | 09:51 AM
  #75
pettrix's Avatar
I looked up the Holley 71221006HKR engine mounts. If the mounts keep the LS engine in the exact same spot. Is the LS2 engine dimensionally (width wise) the same size as the Olds 455?
Old Aug 24, 2021 | 10:31 AM
  #76
70cutty's Avatar
Beer Connoisseur
71221006HKR are forward biased mounts, they are used to locate the engine forward which makes room for 4l80e/4l60e. Since you are using 2004r, you need Holley 71221007HKR, they will locate the engine further back in the stock engine/transmission mating plane. Basically the back of the LS would be in the same position as the back of the olds engine. This way older transmissions don't need to be moved in order to bolt up to LS.
As far as the width, I have no clue.
Old Aug 28, 2021 | 01:19 PM
  #77
Bee Saint Louis's Avatar
CutOvers Olds Parts Guys
Scarebird bracket for dbw pedal
I really want to take full advantage of electronics that LS platform offers so I decided to keep the Drive By Wire system. For DBW I installed LS3 throttle body and pedal from Cadillac CTS.
The bracket to mount the pedal came from Scarebird.
From what I understand pedal from late model Impala is direct bolt in, but I didn't try it.
I like the Scarebird bracket better because it uses existing gas pedal pad mounted on CTS DBW. That way it doesn't look out of place and it bolts in the existing holes.
DBW Throttle body - OEM 12605109
DBW Pedal - 10379038
Mounting Bracket bought from Scarebird $75
any tips on removing old pins in both olds and Cadillac pedals?
Old Aug 30, 2021 | 09:56 AM
  #78
70cutty's Avatar
Beer Connoisseur
If I remember correctly I just used a hammer and a punch, with a socket under it.
Old Aug 30, 2021 | 11:05 AM
  #79
Thanks I got this after seeing your post with it on it
I end up using a cutting wheel for the black plastic Cadillac pedal then sheared the pin closer to the larger headed side. It was just enough so the Scarebird bracket lined up using the remaining pin. I drilled a hole into the dimple of the new pedal arm per the instructions. Also on old pedal I managed to remove pad with the spring and got it all
installed
Old Apr 27, 2024 | 07:05 PM
  #80
cjones55555's Avatar
Following
There is very little room for cooling lines on the transmission, I used banjo fittings bought on Ebay ($40), and 6an line kit from Amazon ($80).
Transmission cooler got installed on 2 brackets that I bolted to the AC condenser mounts.
Transmission mount is OEM for f body.
For shifter I kept my His/Hers Hurst Dual gate and hooked it up using Shiftworks conversion kit, which was perfect.
Transmission cooler - LPD47391
Mount - Anchor 2817
Shiftworks conversion kit for dual gate - SIW-C371
deadeyejedi
Feb 29, 2020 07:12 PM
gibbo69olds
May 29, 2019 01:43 PM
sammieolds
Oct 20, 2015 09:56 AM
540 Olds
Non-Olds Engines
20
Oct 3, 2012 10:45 AM
Fakser
Apr 10, 2012 08:46 PM
