Body mounts on '72 98?
Old May 29, 2023 | 06:56 PM
jpilk99's Avatar
I have to replace the trunk body mounts (4) and likely others. Does anyone have a recommendation on the best deal on line?
Old May 30, 2023 | 04:01 AM
Did you check Fusick or Kanter for the body mounts?
https://www.fusickautomotiveproducts...s.asp?dept=185
https://www.kanter.com/
Old May 30, 2023 | 06:12 AM
I doubt anyone sells body mounts specifically for the Olds full size cars. Ames Performance Products has a page of body mounts in their Full Size Pontiac catalog. You can match them up dimensionally.
Old May 31, 2023 | 05:51 PM
jpilk99's Avatar
Thanks Joe
Old May 31, 2023 | 05:52 PM
jpilk99's Avatar
Thanks - I did not consider them. Will now
Old Jun 1, 2023 | 05:19 PM
jpilk99's Avatar
Tried Fusick but he did not have them. Jokingly said to go down to Dicks Sporting goods and buy some pucks. Best I can do is try and match the sizes of what I need. There are:
2.5" diameter, approx 1.25" thick at the forward mount of the trunk on frame rail.
2.2" dia x 1" thick on the lower rear mount and a big 3.1" dia x 1" above the frame under trunk floor
These are all approximates given the worn out squishies that I pulled out. Any ideas? Just hunt around for anything close?
Old Jun 2, 2023 | 05:01 AM
If you have to do that, I don't think it would be objectionable. In fact, new body mounts made from hockey pucks would probably "perform" better than the OE body mounts you have now. I know the 4x4 crowd and others use hockey pucks in body, engine & transmission mounts.
oilcanman
Jun 13, 2022 08:25 AM
junker garage
Ninety-Eight
Feb 15, 2019 07:09 AM
junker garage
Feb 13, 2019 09:30 AM
kx1233
Jul 21, 2013 07:11 PM
