Body mounts on '72 98?
Did you check Fusick or Kanter for the body mounts?
https://www.fusickautomotiveproducts...s.asp?dept=185
https://www.kanter.com/
2.5" diameter, approx 1.25" thick at the forward mount of the trunk on frame rail.
2.2" dia x 1" thick on the lower rear mount and a big 3.1" dia x 1" above the frame under trunk floor
These are all approximates given the worn out squishies that I pulled out. Any ideas? Just hunt around for anything close?
If you have to do that, I don't think it would be objectionable. In fact, new body mounts made from hockey pucks would probably "perform" better than the OE body mounts you have now. I know the 4x4 crowd and others use hockey pucks in body, engine & transmission mounts.
