64 olds 98 interior lite removal
hi guys
I'm tryin to removal the back pillar interior lite in my 64 98 sedan , so wot is the correct way to taken em out ??? I have trid to turn em , look in factory workshop manual with no luck..not in there???..don't want to brake things ideas????
thanks mate
gino
thanks mate
gino
Use a small thin bladed flat screwdriver to carefully pry the lens out, then push the bulb in and twist to remove as Dave has suggested.
If you break the lenses (round lamps on sailpanels) the lenses are reproduced in both styles- concentric ribbed and flat. If it has larger rectangular lenses not sure if any reproductions are available.
